Author Topic: how much work  (Read 4512 times)
August 07, 2007, 08:48:28 pm
superman293
  • 93
how much work
« on: August 07, 2007, 08:48:28 pm »
I have a 84 rabbit, i wanted to put a gauge cluster out of a jetta in it with a tach,(mine has the clock) would this be hard to do, where would you get a signal for the  tachometer??
thanks
Reply #1August 07, 2007, 10:13:59 pm
how much work
« Reply #1 on: August 07, 2007, 10:13:59 pm »
The signal is from the W terminal on the alternator. It is usually stamped right on the alternator casing.
Are you planning on installing the complete mk2 dash?
Reply #2August 08, 2007, 07:11:47 pm
superman293
  • 93
not sure
« Reply #2 on: August 08, 2007, 07:11:47 pm »
I just wanted a tach for my rabbit, I was hopeing i could just bolt up a cluster with a tach and run wires?
is it not this easy?
Reply #3August 08, 2007, 07:46:25 pm
how much work
« Reply #3 on: August 08, 2007, 07:46:25 pm »
The diesel tach and gas tach have different circuitry because the signal from the alternator of a diesel engine is at a completely different rate than the signal from an ignition system on a gas engine.
There are various conversion techniques... changing the on-board components (ie parts and soldering), a signal conversion box, and of course finding a diesel cluster rather than a gas cluster... for Rabbits a bit of a holy grail.
Search here and at www.vwdieselparts.com and you'll find lots of discussion about the conversions.
Me:  I bought an aftermarket VDO diesel tach for my Rabbit truck... worked very well.
Reply #4August 09, 2007, 08:00:17 am
superman293
  • 93
how much work
« Reply #4 on: August 09, 2007, 08:00:17 am »
where did you find your tach at?
Reply #5August 09, 2007, 09:41:49 am
how much work
« Reply #5 on: August 09, 2007, 09:41:49 am »
Local gauge store ordered it in from VDO... here's a pricey example from eBay that lists a VDO part number:
http://www.oztion.com.au/vshops/item.aspx?itemid=487091&shopid=453
