S-PAutomotive.com
Author Topic: sold out  (Read 51455 times)
Reply #60January 30, 2006, 10:50:01 am
ancient
Re: TDI, 1.9TD (AAZ) and 1.6GTD (RA/SB) nozzles for sale
« Reply #60 on: January 30, 2006, 10:50:01 am »
I have a ecodiesel, which set would you recommand?
Quote from: "Smog"
Quote from: "ancient"
Got more GTD nozzles in stock?  I will need one set,  let me know how much total is including shipping.  Thanks.
Quote from: "Smog"
I got 10 sets of 1.6GTD nozzles (RA/SB engines )
and
25 sets of 1.9TD nozzles (AAZ engines)
85$can each set
add 10$ for fast shipping anywhere
I have a lot of them and you quoted the answer to you question  :lol:
Reply #61January 30, 2006, 11:12:20 am
Smog
  • 160
« Reply #61 on: January 30, 2006, 11:12:20 am »
I recommand to change the pump for a regular TD pump and use GTD nozzles.
the pump is realy the first thing to change for performance
www.VEG-Injection-Service.com
1.6GTD nozzles (RA/SB )
1.9TD nozzles (AAZ )
0.205mm or 0.216mm TDI nozzles
TDI injection pump seal kit
IDI Pump shaft seal
Reply #62January 30, 2006, 11:27:33 am
ancient
sold out
« Reply #62 on: January 30, 2006, 11:27:33 am »
Got you.  But what about the nozzles?  Would I be able to put the GTD nozzles in my injectors myself and balance them? Or do I have to have a shop do it for me?   Thanks a bunch.
Reply #63January 30, 2006, 11:30:26 am
Smog
  • 160
sold out
« Reply #63 on: January 30, 2006, 11:30:26 am »
the GTD nozzles can be installed yourself with a regular torque limiting wrench (something you can rent)
to get the pressures balanced, you will need to take the injectors to a diesel injection specialist; they have a special pressure tester and calibrated shims to readjust the pressures.
IDI Pump shaft seal
Reply #64February 07, 2006, 11:00:07 pm
Jeff@TheQuadShop
  • 42
sold out
« Reply #64 on: February 07, 2006, 11:00:07 pm »
Can you tell me what day mine shipped?
thanks,
Jeff Stoess
Reply #65February 08, 2006, 07:09:15 am
Smog
  • 160
sold out
« Reply #65 on: February 08, 2006, 07:09:15 am »
Quote from: "Jeff@TheQuadShop"
thanks,
Jeff Stoess
Jeff, The nozzles were shipped the very same day I got the paypal confirmation of the cleared payment.
I THINK it was early last week and I sent them airmail.
thank you
Luc Plouffe
IDI Pump shaft seal
Reply #66February 08, 2006, 07:13:26 am
Jeff@TheQuadShop
  • 42
sold out
« Reply #66 on: February 08, 2006, 07:13:26 am »
Ok, thanks.
Reply #67February 15, 2006, 07:22:52 pm
speedball30
  • 18
Nozzles for a 1.9 TD
« Reply #67 on: February 15, 2006, 07:22:52 pm »
Hi Smog,
What injectors do you recommend for the above engine and where do I send the cash...and how much? Do you still accept guys shipping the whole injector valve and have you rebuild them?
Thanks for your help.
1997 Jetta TD 1.9
213,000 Km's
Reply #68February 16, 2006, 08:40:51 am
Smog
  • 160
Re: Nozzles for a 1.9 TD
« Reply #68 on: February 16, 2006, 08:40:51 am »
Quote from: "speedball30"
Hi Smog,
Jeff,
I can install the nozzles and recalibrate your own injectors for 125$+10$ shipping (all included). or the nozzles only are 85$ + 10$ shipping.  Most diesel injection specialists got the toolings to readjust the injection pressures; you can give them a call and check for prices in your area
IDI Pump shaft seal
Reply #69February 27, 2006, 06:37:24 pm
speedball30
  • 18
sold out
« Reply #69 on: February 27, 2006, 06:37:24 pm »
Is it possible that you have a full set of injectors I can buy and then ship mine to you? Reason is this is my only set of wheels right now.
Thanks for the info.
1997 Jetta TD 1.9
213,000 Km's
Reply #70March 10, 2006, 04:49:25 pm
jimbrown618
  • 43
« Reply #70 on: March 10, 2006, 04:49:25 pm »
Hi Smog,
I have a 97 Golf TD with a 1.9 AAZ (340,000+ Km) & am interested in buying a set of injectors for it, if you have any left. If so, PM me your paypal info & I'll send payment for them with my mailing info. I'm in Ontario L0M1C0. Cheers.
Quote from: "Smog"
and
85$can each set
I also carry the 0.205mm and 0.216mm nozzles for the TDI at 160$can
Reply #71March 12, 2006, 07:54:44 am
jimbrown618
  • 43
Payment sent for set of GTD nozzles
« Reply #71 on: March 12, 2006, 07:54:44 am »
Hi Smog,
Payment  of $95 sent last night via paypal. Cheers.
Reply #72June 15, 2006, 08:03:22 am
Smog
  • 160
« Reply #72 on: June 15, 2006, 08:03:22 am »
By the way, I now offer the pop-testing service for IDIs and TDIs.
pop-testing + pressure calibration of IDI (1.6 and 1.9TD) injectors including new nozzles is 125$can + shipping.  And yes I can put the opening pressure you want for your setup.
pop-testing + pressure calibration of TDI injectors including new nozzles is 200$can + shipping.
I can do any non-VW diesel injector if you supply the nozzle; ask for a quote
[email protected]
IDI Pump shaft seal
Reply #73August 21, 2006, 10:35:10 am
Smog
  • 160
Now selling IDI injection pump seal kits
« Reply #73 on: August 21, 2006, 10:35:10 am »
Now selling IDI injection pump seal kits. )genuine Bosch)
so you will be able to repair the leaky IP on your car.
IDI Pump shaft seal
Reply #74August 22, 2006, 08:51:08 am
addautomotive
sold out
« Reply #74 on: August 22, 2006, 08:51:08 am »
How much for a seal kit for a 1.9TD?
Fixmyvw.com
