Author Topic: Glow time...  (Read 4807 times)
August 05, 2007, 11:08:51 am
nokivasara
  • 115
Glow time...
« on: August 05, 2007, 11:08:51 am »
How long is a 1.9TDI -98 supposed to glow when itīs 20deg C outside? I just came home after testdriving a Golf IV TDI and the glowplug light was on for approx 5sec when I first started it.
That is the same as my IDI Passat, Iīm new to direct injecton diesels and I thought they hardly glow at all unless itīs colder outside.
Do you think thats due to a faulty temp sender, or is this a common, more expensive, problem on VW-TDIīs?
Otherwise the car was in really good condition, despite 230k km on the odo and a TB-change coming up, but Iīm pretty sure I can change that myself.
Caddy 1.6N/A pushing 400 000km and going strong!
Reply #1August 05, 2007, 02:07:00 pm
Glow time...
« Reply #1 on: August 05, 2007, 02:07:00 pm »
has that problem just recently come up?  sounds to me like an effort to reduce cold starting emissions & smoke.  my car took roughly 3-4 seconds
@ 25C.
i'm unfamiliar with MK4 TDI's, but maybe someone else is!
Reply #2August 05, 2007, 04:58:55 pm
MacGyver
  • 245
Glow time...
« Reply #2 on: August 05, 2007, 04:58:55 pm »
What elevation are you located at?
TDI's have an altitude compensator, they glow longer the higher you are, to make up for less air to compress.
Reply #3August 05, 2007, 06:36:30 pm
Slave2School
  • 531
Glow time...
« Reply #3 on: August 05, 2007, 06:36:30 pm »
At sea level, mine does not glow at all till it gets to around 10C or less.  If someone has played in vag-com you can adjust when/how long it comes on as well!
2002 ford focme wagon
Reply #4August 06, 2007, 06:32:50 am
nokivasara
  • 115
Glow time...
« Reply #4 on: August 06, 2007, 06:32:50 am »
I live at sea level, so no altitude compensation here! The old lady who owns the car said that she hadnīt noticed when the glowplug light started to stay on longer, she just gets in the car and starts right away.
It might even be a loose connection at the sender, so the car thinks itīs really cold outside..
Oh well, I donīt think itīs anything major, īcos the car started and ran great, Iīm not sure if Iīm gonna buy it though...itīs a little too pricey for my taste :D
Reply #5August 18, 2007, 11:21:02 am
nokivasara
  • 115
Glow time...
« Reply #5 on: August 18, 2007, 11:21:02 am »
My fiancé bought the car, and today I checked the temp sender, or at least made sure it wasnīt loose or corroded. Thereīs 4 wires going to the sender, how can I test it? Itīs an AGR engine by the way.
Then I found out that 3 of the glowplugs where dead, I used a testlight connected to bat+ and the tip of the plug to test them.
Could this cause the GP-light to stay on longer, as some sort of varning that something is wrong?
Reply #6August 19, 2007, 07:04:12 pm
hillfolk'r
  • 1532
Glow time...
« Reply #6 on: August 19, 2007, 07:04:12 pm »
i thought that tdi's would blow a fault code if a glow plug goes bad
my dads 03 golf does
and my moms old 98 did too
but the later ones will tell you which plug is bad
you need a vag-com or equivalent to tell you though
Throttle cables ftw
Reply #7August 20, 2007, 07:45:59 am
Slave2School
  • 531
Glow time...
« Reply #7 on: August 20, 2007, 07:45:59 am »
They do tell you.  It says the cylinder on later cars, but they are numbered backward lol.
Reply #8August 21, 2007, 10:29:53 am
nokivasara
  • 115
Glow time...
« Reply #8 on: August 21, 2007, 10:29:53 am »
Iīm sure it tells you, but I donīt have vag-com so I solved it the old fashion way :D
4 new plugs went in, I saved the one that still worked for later, might come in handy sometime.
Actually the GP light in the dash is still on for 5s or so, either the fault code need to be erased or the temp-sender is faulty.
Does anyone know wich terminal at the sender I should get the ohm reading from, thereīs 4 pins on it.
Itīs not that important, the plugs wont do any damage even if they are on 5s at every start...
