Author Topic: 1,9 to 2,1 liter  (Read 5792 times)
August 04, 2007, 09:49:01 am
ISBjornen
  • 36
1,9 to 2,1 liter
« on: August 04, 2007, 09:49:01 am »
What is the advantage of drilling from the original 1,9 to 2,1 liter?
Kristensen
Reply #1August 04, 2007, 12:56:14 pm
1,9 to 2,1 liter
« Reply #1 on: August 04, 2007, 12:56:14 pm »
will the block even support that?  it would be higher displacement, more power, more fuel consumption, and more problems down the road due to change in compression etc.
Reply #2August 04, 2007, 01:46:29 pm
Black Smokin' Diesel
  • 656
1,9 to 2,1 liter
« Reply #2 on: August 04, 2007, 01:46:29 pm »
Quote from: "jtanguay"
I don't think compression will change, well the compression ratio I mean. Quite frankly, I don't think you can bore it to 2.1. The cylinder walls are gonna be way too thin to support any major power. You can't bore a diesel that much like you can on a gasser.
Reply #3August 04, 2007, 03:47:28 pm
Benjamin
  • 485
1,9 to 2,1 liter
« Reply #3 on: August 04, 2007, 03:47:28 pm »
how much space is there with a 1.9 and a 1.6 between 2 cilinders? i mean how tick is the wall. if its smaller, maybe we realy realy do need more better solutions for headgasketproblems
Greetz, Benjamin
Must make +250hp
Reply #4August 04, 2007, 03:51:51 pm
Slave2School
  • 531
1,9 to 2,1 liter
« Reply #4 on: August 04, 2007, 03:51:51 pm »
I know of a 2.0L down this way that is being built for a rabbit pickup :D
2002 ford focme wagon
Reply #5August 04, 2007, 06:14:38 pm
scopefrfd
  • 289
1,9 to 2,1 liter
« Reply #5 on: August 04, 2007, 06:14:38 pm »
using the pistons from an audi 2.5 tdi will yield a 2.0L.  You need 83mm pistons to get 2067cc aka a 2.1L.  That's pretty thin between the cylinders...gassers have taken the block out to 83.5mm
Reply #6August 04, 2007, 06:34:31 pm
1,9 to 2,1 liter
« Reply #6 on: August 04, 2007, 06:34:31 pm »
Quote from: "Black Smokin' Diesel"
if you can find pistons that are exactly the same as required to have the same compression ratio then i guess you're right, but good luck finding it!  :lol:
Reply #7August 04, 2007, 08:16:19 pm
  • 656
1,9 to 2,1 liter
« Reply #7 on: August 04, 2007, 08:16:19 pm »
Quote from: "libbybapa"
The compression ratio does indeed go up when overboring due to the fact that the combustion chamber (the 1 part of the ratio) remains the same yet the volume of the cylinder (the bigger number) increases.
Andrew
Geez major brain fart... you're right. I was only thinking about piston travel (which doesn't change) but didn't compensate for the added volume :oops:
Reply #8August 05, 2007, 01:43:34 am
Benjamin
  • 485
1,9 to 2,1 liter
« Reply #8 on: August 05, 2007, 01:43:34 am »
My Fiat do have 82,6mm pistons, wanna buy a set.  :wink:
Greetz, Benjamin
Must make +250hp
Reply #9August 11, 2007, 07:48:54 am
ISBjornen
  • 36
1,9 to 2,1 liter
« Reply #9 on: August 11, 2007, 07:48:54 am »
how big i the audii 2,5tdi pistons? im thinking about them, im also planing to try a 1z top and block with oil cooling on the pistons. but whit my 12 mekanikal pump. and 2 step injkectors
ideas?
Kristensen
Reply #10August 14, 2007, 11:47:11 pm
Benjamin
  • 485
1,9 to 2,1 liter
« Reply #10 on: August 14, 2007, 11:47:11 pm »
this guy use the 2.5pistons
http://www.centralvwaudi.com/tdi.htm
i think 2step injectors are good for economical, but i think fot best perfomance you better use 1step.
Greetz, Benjamin
Must make +250hp
Reply #11August 15, 2007, 04:09:36 am
stewardc
1,9 to 2,1 liter
« Reply #11 on: August 15, 2007, 04:09:36 am »
My pistons are first oversize and that will give a hair less than 2 liters. I think it will give slightly more torque.
Reply #12August 17, 2007, 12:10:39 am
ISBjornen
  • 36
1,9 to 2,1 liter
« Reply #12 on: August 17, 2007, 12:10:39 am »
I will be running 2 step ionjectors, will alos use a 1Z top butt whit the aaz injector pump, maby ill use the 1Z bottom becuse of the oil cooling on the pistons.
Kristensen
Reply #13August 17, 2007, 02:45:04 am
stewardc
1,9 to 2,1 liter
« Reply #13 on: August 17, 2007, 02:45:04 am »
Quote from: "ISBjornen"
All turbodiesels have oil cooling on the pistons, and if you use a 1Z top, you gotta use a 1Z bottom :wink:
Reply #14August 17, 2007, 11:12:12 am
ISBjornen
  • 36
1,9 to 2,1 liter
« Reply #14 on: August 17, 2007, 11:12:12 am »
non of the 4 AAZ enigens i have worked whit have it.
Kristensen
