Author Topic: K26 turbo ?  (Read 3122 times)
August 03, 2007, 05:39:30 pm
KAC
  • 35
K26 turbo ?
« on: August 03, 2007, 05:39:30 pm »
K26 turbo are they worth putting on my 1.6td?
Suzuki samurai with VW TD
Reply #1August 03, 2007, 06:33:55 pm
K26 turbo ?
« Reply #1 on: August 03, 2007, 06:33:55 pm »
What does your TD have now... Garrett T3 ?
Reply #2August 04, 2007, 04:54:23 am
KAC
  • 35
K26 turbo ?
« Reply #2 on: August 04, 2007, 04:54:23 am »
it use to...now it has another KKK (not sure of #) now...The K26 is off of a Audi 4000
Reply #3August 04, 2007, 08:59:06 pm
D1ES3L
  • 62
K26 turbo ?
« Reply #3 on: August 04, 2007, 08:59:06 pm »
probably not... pretty sure the k26 has the additional coolant lines as well as the manifold flange being trapezoidial or vice versa.  Does that make sense??  Maybe you could swap internals to your k24 or t3 though.
81 scirocco--80 TD caddy--99.5 TDI golf
Reply #4August 04, 2007, 11:07:35 pm
Black Smokin' Diesel
  • 656
K26 turbo ?
« Reply #4 on: August 04, 2007, 11:07:35 pm »
You can make a k24/26 hybrid using the k24 turbine housing with the k26 compressor side. IIRC, the K24 uses k26 internals.
Reply #5August 05, 2007, 04:25:56 am
KAC
  • 35
K26 turbo ?
« Reply #5 on: August 05, 2007, 04:25:56 am »
Quote from: "D1ES3L"
I all ready made an adapter to the manifold...as for the coolant lines are no problem
Reply #6January 08, 2008, 05:12:31 pm
dillenger1
  • 777
K26 turbo ?
« Reply #6 on: January 08, 2008, 05:12:31 pm »
I may be getting a #6 k26 from an audi 5000.I would like to know if it will spool up.It seems like its on the large side.What can be done to help with lag?I have the engine completely disassembled.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #7January 08, 2008, 08:07:17 pm
subsonic
  • 1836
K26 turbo ?
« Reply #7 on: January 08, 2008, 08:07:17 pm »
No experience, but from reading here, people have stated it would be a lag monster.  Too big.
