Author Topic: Air con onto Mk2 GTD (SB)  (Read 13813 times)
August 02, 2007, 03:35:24 pm
MontanaGTD
  • 230
    • http://www.dub-style.com
« on: August 02, 2007, 03:35:24 pm »
Ok in the Uk air con was never offered even as an option on the 1.6 TD mk2 golfs. I want to know what i need and if anyone in the USA or Canada has air con on an SB intercooled MK2?
But i'm going through upgrading everything on the car - here is what is planned:-
256mm discs upfront along with a GTi rear axle with rear discs - but i'm also pulling the ABS kit off a Seat Toledo GT MK1 (basically a mk2 golf underneith) it all plugs in straight into the fuse box and the sensors are mounted into the calipers of the Toldeo (they run the exact same front struts as a mk2 golf)
Power steering rack
Coilovers
8x15 et 25 Schmidt Modern Lines with 195/45/15's
full retrim in Grey nappa leather
New big bumpers and full g60 spec kit all smoother of their texture and painted metallic black and colour coded sections to stop them fading and keep thing smooth
mk3 style golf door handles (chinese style)
Single lamp OEM grill with Montana Green strip - eyebrow spoiler
HID's
electric sunroof
new black GTi headling and c-pillar sections
full body restoration - inc new drivers side wing and full glass out respray in Montana Green
Under the bonnet - parts polished and painted either black or Montana green.
I've just got a new job and i'll be making £10,000 more than i make at the moment! So rather than buy a new car with no character I thought i'd update my golf and keep it for another 5-10 years instead!
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #1August 02, 2007, 03:37:19 pm
MontanaGTD
  • 230
MK3 Polo G40 - Sold
Reply #2August 11, 2007, 11:58:15 pm
blkboostedtruck
  • 1535
« Reply #2 on: August 11, 2007, 11:58:15 pm »
Quote from: "MontanaGTD"
if you are interested this is what the seat Toledo looks like - http://cgi.ebay.co.uk/Seat-Toledo-1-9-GLX-Turbo-Diesel-12-Months-MOT_W0QQitemZ330144241037QQihZ014QQcategoryZ18270QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  that car looks like a (mazda pro`tejae) i don't think i spelled that right? or it looks like a (ford escort) that we have here in the USA! and it's RHD I wish it was easy to make my caddy RHD ? I always wondered if i can shift left handed? now that would get me back into the right side sead again! L.O.L.
thanks Duane
 P.S. MontanaGTD do you have caddys where you are at? if so! i'm looking for all red tail lights the one's that don't have the amber turn signal lense! the one's that are all red with the clear backup lens? let me know if you can help me with that request?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3May 13, 2010, 09:40:04 am
funnyceline
  • 1
Re: Air con onto Mk2 GTD (SB)
« Reply #3 on: May 13, 2010, 09:40:04 am »
It could be just fine for you about the air con. Since you are not in UK, so you could be just fine for that. Otherwise,you have to try other if you are willing to.
« Last Edit: May 14, 2010, 12:01:40 am by funnyceline »
newbielink:http://www.computerseo.com [nonactive]
Reply #4May 13, 2010, 01:00:09 pm
« Reply #4 on: May 13, 2010, 01:00:09 pm »
As far as I know, the U.S. (and Canada) didn't get any GTDs and no intercooled MK2s, an just n/a diesel and turbo-diesel (which was only available on the Jetta IIRC) and n/a gasoline engines... So anyone that has an intercooled diesel MK2 Golf (such as my car) were homebuilt customs or were brought over from Europe.
I also believe (but do your own research on this) that the brackets, pulleys, a/c pump and alternator from the gasoline engines will swap right over to the diesel and allow you to install a/c.
I do not know if the presence of the intercooler and it's piping will interfere with this or if the RHD dashboard will present a problem for the installation of a/c components.
I am also laughing a bit  ;D and rolling my eyes a little  ::) at your need for a/c in Scotland of all places whereas I don't have air con in my home or vehicles and it is going to be over 100 F (I think thats like 40 C) in a couple months.
Reply #5August 12, 2014, 11:56:06 am
phaetonv10
  • 83
« Reply #5 on: August 12, 2014, 11:56:06 am »
a big hello from pakistan.
I have a 1986 mk2 golf, originally NA 1.6D. My car had an AC from factory.
I recently sourced a GTD engine, code SB, along with intercooler and all the plumbing. And the AC pipe going from compressor to the evaporator inside the dash and the one going from compressor to condenser in the front, both will require rerouting if you want the original IC to fit.
OR you can do what i did and go FMIC.... ;D
One thing you should ensure is the BIG TD radiator, and the fast turbo fan. I changed fan shroud and am now running a AAZ twin fan setup. shroud had to be cut a bit, but fits like it belongs..... 8)
Cheers
THE LEMON
1.6 GTD, FMIC, ARP Studs, Brembo brakes, Power Clutch, ibiza tdi twin fan setup, Racing Seats, 40 mm all aluminium radiator, audiophile music.
Reply #6November 21, 2014, 05:35:02 pm
GEE-BEE
  • 1604
« Reply #6 on: November 21, 2014, 05:35:02 pm »
Iam setup as a oem
fanassy 330
new radiator
 two hoses
two mounts
 for 425.00
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
