Author Topic: ESS  (Read 2721 times)
August 02, 2007, 12:25:59 am
ezekiel
  • 147
ESS
« on: August 02, 2007, 12:25:59 am »
so, I think I have a bit of a problem.
I was going to go mechanical, but scored a mk3 TDI wiring harness, so I decided I'll go electronic.
but, my TDI is different, I'm taking an AAZ block and converting it to a TDI,
so I don't think my crank has provisions for an ESS sensor
does anyone have any pictures as to where and how it mounts?  Maybe I can mod my block and crank, or, at the very least, add a hall sensor plate to the crank pulley and run it like that, but I want to see if there's a factory way to do it first.
thanks
ESS = engine speed sensor
Reply #1August 03, 2007, 04:18:44 pm
ESS
« Reply #1 on: August 03, 2007, 04:18:44 pm »
well you need a TDI crank then.   it will have a wheel on the inside with slots (to measure engine rpm)
you will most likely need to have it machined in.  i don't think any 1.9's came with it, but you might be lucky... my block is still in my trunk so maybe i'll check it out unless someone else chimes in.
