Author Topic: Motor differences  (Read 5231 times)
February 07, 2005, 05:52:38 pm
1stdiesel
Motor differences
« on: February 07, 2005, 05:52:38 pm »
What are the differences between the 1Z and the AHU motors? Will the heads and blocks interchange? How about bolt up to the tranny?Thanks for any and all info.
Reply #1February 07, 2005, 06:31:46 pm
Piper106
  • 24
Motor differences
« Reply #1 on: February 07, 2005, 06:31:46 pm »
All VW four cylinder water cooled engines, from a 1975 era 1.5 L gas through the newest 2.0L PD diesel have the same trans bolt pattern, so the trans should bolt up no problem.
As far as I know the 1Z and the AHU long blocks are the same, so the heads or blocks should interchange either way.
The only difference I am aware of between the two engines was the turbo charger. 1Z usually was supplied with a Garrett GT15 turbo, the AHU had a KKK03 turbo.
Piper106
Reply #2February 23, 2005, 10:43:03 am
gbangs
  • 1
Motor differences
« Reply #2 on: February 23, 2005, 10:43:03 am »
My early '97 1Z has a KKK. It was supposedly replaced sometime before I bought it.
As far as I know, the Garrett and KKK turbos of this era are interchangeable as well.
-Gary
1980 VW P/U
1997 Passat TDI
