Author Topic: Vacuum issues  (Read 4256 times)
July 30, 2007, 04:16:11 pm
detour1999
  • 7
Vacuum issues
« on: July 30, 2007, 04:16:11 pm »
The car:
1991 Jetta 1.6 NA ~280K miles.
Here's the situation:
-no vacuum at idle
-vacuum is fine (~25in) after revving.
-as soon as brakes are pressed, vacuum is gone, and must be re-revved to have any vacuum again.
Here's what has recently been done (which is to say, in the immediate past... Vacuum hasn't worked since):
-new head (yeah.)
-new 1.9 metal hg.
-new oil pump (36mm)
-new oil pan gasket (actually, the one w/ the baffle)
-new injectors (stock rebuilds)
-new vacuum pump (was, and still is the vane style, replaced after all other things, after the vacuum problem surfaced, was purchased hoping to fix this specific problem)
notes:
-My IP is VERY old and worn (I'm in touch w/ Giles to get a nice reworked one) but for the time being, it's only happy @ 1.1-1.15.  It's @ 1.1 right now.
-oil pressure (cold) is 100+psi at the filter flange.
-brake booster has been tested and holds vacuum.
I'm at a loss.
Anyone ever experience something like this?
Anything I should check that I haven't already?
Reply #1July 30, 2007, 06:04:10 pm
Vacuum issues
« Reply #1 on: July 30, 2007, 06:04:10 pm »
Where are you measuring vacuum from?
Reply #2July 30, 2007, 06:13:43 pm
detour1999
  • 7
Vacuum issues
« Reply #2 on: July 30, 2007, 06:13:43 pm »
Quote from: "burn_your_money"
measured from all vacuum ports...  pump to booster.
-d.
Reply #3July 31, 2007, 01:41:48 pm
Trimster
  • 74
Vacuum issues
« Reply #3 on: July 31, 2007, 01:41:48 pm »
Even after I got my vac. pump in, timed, etc. I still had low break vac.  Found there was nearly a cup of oil in the bottom of the break booster.  Sucked that out... all is well in the world.
Bob
'83 Caddy, 1.6 NA Diesel, 5 speed, AC
2- motorcycles, 36' 5th wheel, sailboat, RC airplanes... to many interests, not enough time.
Reply #4August 02, 2007, 09:00:05 am
detour1999
  • 7
Re: Vacuum issues
« Reply #4 on: August 02, 2007, 09:00:05 am »
Quote from: "detour1999"
The culprit.
Oil pump works great (as I mentioned, oil pressure checked on a mechanical gauge @ filter flange is outstanding...), however, it had apparently been sitting on the parts supplier shelf for a while..
There was a small amount of rust buildup on the oil galley that feeds oil to the vacuum pump to push the vanes out.  Not enough oil getting up there: no vacuum at idle.  As RPM go up (2,500+), centripetal force was pushing the vanes out, creating enough vacuum for one press of the brakes.
Oil pump removed, oil galley cleaned, reinstalled.  Now pulls ~30in at idle.
Cliff Notes version
Check/clean the oil galley that feeds the vacuum pump when you get a new oil pump.
Side note, new head, injectors, exhaust (tubular manifold to 2" exhaust), new oil pump, new vacuum pump...  I'm in love with my car again.
-d.
