Author Topic: Can't get my dash apart  (Read 4367 times)
February 06, 2005, 01:59:49 pm
Antebios
« on: February 06, 2005, 01:59:49 pm »
Hey guys i was goin to put a new head unit in my rabbit because the old one stoped working, and when i went to take the dash apart i found that i cant get the knob off the headlight switch.
So how do you get that little knob off?
Reply #1February 06, 2005, 02:17:41 pm
Dr. Diesel
  • 1341
« Reply #1 on: February 06, 2005, 02:17:41 pm »
look on the switch body, there's a small button you push that releases the knob and it's shaft from the switch. little button, about 4mm in diameter.
Reply #2February 10, 2005, 08:15:13 pm
MK3 GTD
  • 48
« Reply #2 on: February 10, 2005, 08:15:13 pm »
remove left dash speaker and reach in towards headlight switch you will feel a small button on the left side of the switch push that and pull out knob. you may have to gently push the knob back so that it doesnt lock back in in order to turn off the lights if you didnt unplug the battery.
1996 Golf 1.9TD
1984 Rabbit 1.6TD
1987 Jetta Coupe 1.6D
