Author Topic: IT APPEARS I HAVE BIGGER PROBLEMS THAN A LITTLE FUEL LEAK  (Read 9278 times)
July 29, 2007, 08:23:38 pm
Infinitrium
  • 151
« on: July 29, 2007, 08:23:38 pm »
GRRRRRRRRRRRRR!!!! I was out for a drive earlier, and on the way home I decided to let the car stretch its legs a bit, so to speak. I was only doing around 140 kmh to be honest. I noticed a few times at this speed the temperature gauge climed up, at one point on a tall hill at 125 kmh in 4th at WOT, it went over the 110 celsuis mark but at the time I wasn't worried, the needle went down again when I went back down the hill. I just figured the engine was working really hard and never thought any more about it. About a mile from the offramp to get home I just laid my right foot down to see what the car could do. It got up to about 160 kmh before I had to slow down for the offramp. I came up to the stop sign and saw clouds of what I thought was smoking brakes but I realized it didn't smell like hot brakes. I thought everything was fine up to this point until I pulled away from the stop sign, leaned forward in my seat and saw THE ***ING TEMP WARNING LIGHT FLASHING!!!!! Well that was just great, I had no idea how long it was on for. With the way I have my seat and steering wheel adjusted the light was hidden by the plastic thing behind the steering wheel. I just drove on gently keeping one eye glued on the temp gauge. It (the gauge) eventually fell back to its normal position but the warning light kept flashing. I got home and straight away added some warm water to the coolant bottle with the engine idling. It took nearly 2 liters (2 quarts roughly) to bring the level in the bottle up full. I also noticed the engine sounded like it was idling a bit rough, somewhat like one cylinder partially misfiring. There seems to be a wet area on the back of the engine below the turbo, plus I saw some dripping coolant from under the car from the same area roughly. Great, so what, I probably warped or cracked the head? I'll have to get underneath it tomorrow to see if I can find what piece broke that allowed the coolant to leak out. What a day.....
PS: Sorry for yelling and cursing, I'm a bit frustrated at the moment.
Reply #1July 30, 2007, 10:31:19 am
« Reply #1 on: July 30, 2007, 10:31:19 am »
You  may have blown the headgasket, the head could still be fine
Reply #2July 30, 2007, 11:29:29 am
« Reply #2 on: July 30, 2007, 11:29:29 am »
that sucks man :(
is it a 1.6TD? a 1.9 HG may solve your problem.  Hopefully there isn't much damage to your head.  Depending on the level of black smoke coming from the rear of your car under full load, you might be okay (little or no smoke = not too high egt's which is what you want)
depending on the amount of cash you can throw at this motor, there is a product that can stop coolant leaks:
www.steelseal.com
Reply #3July 30, 2007, 11:51:02 am
bevboyy
  • 200
« Reply #3 on: July 30, 2007, 11:51:02 am »
That stuff is just a band aid solution. Will also affect your water pump which not good. Sounds like the HG was on it's way out based on the previous post the original poster made. Do the job right once. Take the head off, bring it to a shop and have it checked for trueness. Then install a new head gasket, new studs, and refill your coolant. You will most likely have to drop the oil pan and  clean any coolant in the pan as coolant will make your bottom end bearings mush...
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #4July 30, 2007, 01:33:48 pm
saurkraut
  • 904
« Reply #4 on: July 30, 2007, 01:33:48 pm »
"I was out running the beejeepers out of my car. The temp gauge went up higer than I've ever seen it go befor.  So I ragged on it some more till it blew....." :roll:
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #5July 30, 2007, 02:44:36 pm
« Reply #5 on: July 30, 2007, 02:44:36 pm »
The light could have come on because of low coolant, and it will stay on until the ignition is shut off.. it latches.
The engine temp gauge may have returned to "normal" because it was dry... no coolant circulating.
Most likely a hole in the head gasket, but could also be a frost plug or block heater letting go...  look at the back of the engine from under the car... maybe you got lucky.
Reply #6July 30, 2007, 05:36:22 pm
Infinitrium
  • 151
« Reply #6 on: July 30, 2007, 05:36:22 pm »
Quote from: "Vincent Waldon"
My brother looked at it today, he said to him it looks like its leaking from around a bolt near a rail or something underneath the turbo. I'll have to give it a closer look tomorrow. Any guesses?
Reply #7July 30, 2007, 05:51:27 pm
« Reply #7 on: July 30, 2007, 05:51:27 pm »
the only thing that looks like a "rail" is the headgasket, but "rail" isn't exactly a technical term so it could still be alot of things
Reply #8July 30, 2007, 07:40:53 pm
« Reply #8 on: July 30, 2007, 07:40:53 pm »
Unless "rail" means a manifold... below that is the head gasket.... and then the frost plugs/block heater.
I got lucky with it being the block heater exactly once.
Reply #9July 31, 2007, 07:49:14 am
bvolks73
  • 183
« Reply #9 on: July 31, 2007, 07:49:14 am »
I bought the motor that's in my car now for $150 assuming it needed a head gasket because the PO said it was using a lot of coolant and he couldn't figure out where it was going. Pulled the motor and when I took the manifolds off noticed the block heater was really loose. Figured I had nothing to lose by trying it and got 5 years out of it without losing a drop of antifreeze until I overheated it this winter and really blew the headgasket.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #10July 31, 2007, 06:17:34 pm
Infinitrium
  • 151
« Reply #10 on: July 31, 2007, 06:17:34 pm »
I checked it again today and found something. The leak appears to be coming from some kind of tube, I saw coolant spraying from it. It doesn't seem to spray all the time though. Anyone know what that tube is?
Reply #11July 31, 2007, 07:25:40 pm
« Reply #11 on: July 31, 2007, 07:25:40 pm »
Where is the tube? on the back of the engine?
Reply #12July 31, 2007, 07:27:23 pm
Infinitrium
  • 151
« Reply #12 on: July 31, 2007, 07:27:23 pm »
Yeah, back of the motor, below the turbo. Coolant distribution pipe?
Reply #13July 31, 2007, 08:07:10 pm
« Reply #13 on: July 31, 2007, 08:07:10 pm »
is it directly behind the engine or to the side? I don't recall there being any coolant pipes back there, maybe a picture to clarify?
Reply #14July 31, 2007, 08:42:47 pm
« Reply #14 on: July 31, 2007, 08:42:47 pm »
No tubes back there on any A1/A2 Ive ever seen.   Frost plugs and potentially a block heater, who's cord I suppose could look like a tube, given enough dirty oil and grease ??
