Author Topic: CE2 diesel cluster with tach  (Read 3770 times)
July 29, 2007, 03:32:32 pm
Black Smokin' Diesel
  • 656
« on: July 29, 2007, 03:32:32 pm »
50$ CAD plus shipping. Paypal only
I can put the odometer to whatever km you want before shipping it. Works with any CE2 MK2 diesel. It runs off the W terminal and it should already be wired to do so in your car.
I'm including about 6" of wiring off the main connector in case you want to install it in a CE1 car and splice all the wires.
For some reason it has a 220km/h speedo.
Reply #1July 02, 2008, 04:51:33 pm
hippiehulahooper
  • 3
MK2 CE2 diesel cluster with tach
« Reply #1 on: July 02, 2008, 04:51:33 pm »
is this still for sale?
how much to 40391?
thank you
90 Jetta chasis, NA engine not original, no second oil return.
parts needed:drivers side rain gutter, drivers side rocker panel and rear flare
86 Jetta TD(bottom end needs rebuild)
