Author Topic: ALH engine and ECU management in 1998 Jetta  (Read 11890 times)
Reply #15August 23, 2007, 01:38:33 pm
vwmike
  • 1158
« Reply #15 on: August 23, 2007, 01:38:33 pm »
The can wires aren't really used for diagnostics in MK4's. They're more or less the on-board "internet" of sorts for the ECU to talk to the cluster, ABS controller, trans controller, etc. So long as you have the K-line running to the diagnostic port it should work fine. Though, without the cluster you will have a code for data bus something or other. Basically a code because the cluster isn't there and possibly another for the missing ABS and airbag controllers. Your check engine light will not work since it runs off of the can-bus system and neither will the glow plug light unless you get creative.
Reply #16December 14, 2007, 07:15:28 am
4BTA4ME
« Reply #16 on: December 14, 2007, 07:15:28 am »
VWMIKE,
     It looks like I can have the ABS and airbag MIL signal inhibited but I'm curious about what this J533- "Data Bus On Board Diagnostic Interface"  modlue does in the ALH instrument cluster. Do I need work arounds or additional defeats for missing signals from that?
