Author Topic: WTB Dport intake  (Read 4529 times)
July 17, 2007, 09:37:20 am
boostin
  • 17
WTB Dport intake
« on: July 17, 2007, 09:37:20 am »
I'm looking for a long runner intake (gasser maybe?) that I can use for a mod on my ALH head. I liked the look of the euro AAZ intake that RabbitGTDguy previously posted, but is sold. The main thing I'm wanting is longer individual runners with a greater radius than the ALH manifold. The plenum will most likely be modified. I have several log type plenums already fabricated, but would rather use longer runners instead of using the bottom portion of the ALH with a open riser below the plenum.
Let me know what's available, and any ideas would be appreciated.
Ken
89 A2 Jetta restored to mostly original/stock
01 A4 Jetta 133000 w/lots of mod's
84 D50 Mighty Max P/U rice smoker
79 HOT Trans AM, Bandit look-a-like
73 F250  428 CJ  (update.. CJ has left the building)
there are more...
Reply #1July 17, 2007, 06:33:18 pm
RabbitGTDguy
  • 1274
WTB Dport intake
« Reply #1 on: July 17, 2007, 06:33:18 pm »
The only long runner "D" port intake manifold you are going to find will be the AAZ manifold. There is another variation of the SDI manifold as well that is a two part manifold and looks alot like the 2.0 gasser (mk3/4 style) manifolds but the "D"port portion is very small and very similar to that of the ALH/1z, other TD manifolds, etc.
If you want to do something similar to the one that I have done you'll have to start with a traditional gasser manifold and port it to D ports...or find a AAZ unit. I've never seen any gasser with D ports even though there are some other port designs out there (16v, 20v, etc...).
Joe
1972 VW Westfalia
Reply #2July 17, 2007, 08:15:16 pm
WTB Dport intake
« Reply #2 on: July 17, 2007, 08:15:16 pm »
I think he is looking for the intakes from across the pond
Reply #3July 18, 2007, 04:04:03 am
RabbitGTDguy
  • 1274
WTB Dport intake
« Reply #3 on: July 18, 2007, 04:04:03 am »
across the pond or in the U.S. you'll be hard pressed to find a D port intake with long runners other than the AAZ intake manifold or the 2 piece, SDI manifold. Thats the point I was making. The AAZ unit isn't even readily available in the U.S. There are a few around...but they are all from europe in one form or another as the non-TD AAZ didn't really make a showing in canada...nor did the SDI.
Joe
1972 VW Westfalia
Reply #4July 20, 2007, 03:23:34 am
boostin
  • 17
WTB Dport intake
« Reply #4 on: July 20, 2007, 03:23:34 am »
Quote from: "RabbitGTDguy"
Joe
Yes... I liked the long radius of  the AAZ non-TD intake. Something along this line should work with my idea for a more efficient intake. If nothing is available, I may have to fabricate from the head up. I mostly need some form of runners to make it easier.
Are there any detailed photos available of the SDI lower portion, starting at the head ? And if so, does anyone have one that they would part with ?
Ken
there are more...
Reply #5July 20, 2007, 07:09:15 am
aidan
WTB Dport intake
« Reply #5 on: July 20, 2007, 07:09:15 am »
I'll be getting an SDI lower soon, i'll get some photos up when I do.
I'm hoping it will mate up to the US spec 2.0 upper I got, but we'll see.
The SDI upper is plastic and a few people have had problems with higher boost causing problems.
Mine will be mainly to help clear smoke so I might be ok with the plastic section
Reply #6July 22, 2007, 09:35:22 am
boostin
  • 17
WTB Dport intake
« Reply #6 on: July 22, 2007, 09:35:22 am »
This could be a rare find, in the mean time, I will be happy to take a alh intake ( and/or other tdi ) to experiment with, if someone has one taking up space.
there are more...
Reply #7July 22, 2007, 11:35:13 am
Mk2Fanatic
  • 93
WTB Dport intake
« Reply #7 on: July 22, 2007, 11:35:13 am »
I'm using a long runner Gasser Manifold mk1 GTI or possibly mk2 digifant2 with a G60 TB adapter.  Depends on what side my piping will run.  I've seen several articles about people modding the port area of a gasser manifold by welding them up in order to make a d port runner...
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
