Fixmyvw.com
Author Topic: Serp setup on a 1.6  (Read 52768 times)
Reply #15October 05, 2007, 04:08:55 pm
flapjack
  • 283
Serp setup on a 1.6
« Reply #15 on: October 05, 2007, 04:08:55 pm »
other numbers for the serpentine bracket from AAZ
028 903 143AB
028 903 139J
028 903 139T
I tried the ABA crank pulley / harmonic balancer but doesn't work with this bracket
you have to get the one from the AAZ
signature
Reply #16November 05, 2007, 07:57:07 pm
the4ork
  • 331
Serp setup on a 1.6
« Reply #16 on: November 05, 2007, 07:57:07 pm »
what is the part number for the bracket and water pump pulley??
Reply #17February 07, 2008, 11:25:10 pm
flapjack
  • 283
Serp setup on a 1.6
« Reply #17 on: February 07, 2008, 11:25:10 pm »
water pump pulley for serp belt is from an obd1 vr6
signature
Reply #18February 24, 2009, 07:30:05 am
Serp setup on a 1.6
« Reply #18 on: February 24, 2009, 07:30:05 am »
Way to step it up a notch :D
What you are saying about the 4th bolt does make sense. I guess time will tell
Reply #19March 09, 2009, 08:24:41 pm
wizard-of-od
  • 18
Serp setup on a 1.6
« Reply #19 on: March 09, 2009, 08:24:41 pm »
if you guys give me some time
I will be doing a complete write up using every bracket out there INCLUDING the AFN unit.
Issam N. Abed
INAEngineering.Com
AIM : ISSAMABED | PHONE : 613.867.8667 | 510.275.4775
Reply #20March 09, 2009, 10:36:50 pm
subsonic
  • 1836
Serp setup on a 1.6
« Reply #20 on: March 09, 2009, 10:36:50 pm »
Cool beans.  Gotta like complete write-ups in the FAQ section!
Reply #21December 15, 2009, 11:38:47 am
ashleyroe
Re: Serp setup on a 1.6
« Reply #21 on: December 15, 2009, 11:38:47 am »
Why would anyone want serp belts on a 1.6?????? Your going the wrong direction here making things more expensive and less reliable! The tensioners always fail on the serp belt set up, the bushings wear out, they stress the crank noise and lead to massive failures if the above parts are not maintained, the mk3 p/s pump will not fit a 1.6 cause the rear bracket has wider bolt spacing which does not exist on the 1.6 block (already found that one out installing a 1.6 into 96 Jetta)
A vbelt costs $5 and last years...
phffff...
Reply #22December 15, 2009, 02:05:55 pm
ashleyroe
« Reply #22 on: December 15, 2009, 02:05:55 pm »
Ashley, if I'm not mistaken, you have the AFN setup with the spring under the alt, correct?  Is the AFN bracket held on by the same four points with the boss for the bolt by the injection missing on the 1.6?  Did you compensate for the missing bolt in any way?
ABF set up <3
i think you asked about that before. i didn't use the fourth bolt.
picture of bracket with alternator removed.
« Last Edit: December 15, 2009, 02:09:54 pm by ashleyroe »
Reply #23December 16, 2009, 11:35:32 am
ashleyroe
« Reply #23 on: December 16, 2009, 11:35:32 am »
no problem.
Reply #24March 17, 2010, 12:23:35 am
Turbinepowered
  • 1206
« Reply #24 on: March 17, 2010, 12:23:35 am »
Are the ABF and AFN setups Euro things that I'd have to hunt for and order up?
Reply #25March 17, 2010, 09:11:50 am
ashleyroe
« Reply #25 on: March 17, 2010, 09:11:50 am »
you can order the ABF or piece it together yourself.
Reply #26April 01, 2010, 03:59:03 pm
« Reply #26 on: April 01, 2010, 03:59:03 pm »
Issam, you rock.
I'm very interested in this as well.  The v-belt setup when you have AC and PS is sketchy at best.  My main concern, since this Golf belongs to my Wife, is if she looses one of three V-belts while driving down the road, she's basically screwed.  She is fairly mechanically competent, but I doubt she would be able to replace a V-belt with the current setup on the side of the road.  I don't think I would even attempt it.  A serp belt, on the other hand, would be a hell of a lot easier.  I had to pull the PS pump after it was all together, and I could not get the adjustment on the PS pump to loosen enough to remove the belt, I had to unbolt the pulley from the hub to get it off.
It would be nice if there was another way besides the unobtainum AAZ stuff for us in the 'States.
Reply #27April 02, 2010, 03:14:13 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #27 on: April 02, 2010, 03:14:13 am »
sweet avatar allusion.
Ed
Reply #28April 02, 2010, 11:55:21 am
MJF
  • 581
« Reply #28 on: April 02, 2010, 11:55:21 am »
Did some mock-up for my 1,9 build. Serp setup is from AEF, crank pulley from AFN. AEF crank pulley is ~inch larger, wanted to use a little smaller one.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #29April 03, 2010, 03:08:15 am
MJF
  • 581
« Reply #29 on: April 03, 2010, 03:08:15 am »
Nope, itīs stock setup. Pump is different.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
