new exhaust
Topic: new exhaust (Read 3343 times)
January 23, 2005, 02:52:18 pm
mainer
new exhaust
January 23, 2005, 02:52:18 pm »
anyone have pictures of there custom bigger exhaust on turbo 1.6's or 1.9's.....
how did u make the down pipe? flex pipe or mandrel bend?
how muhc of an improvement did you see after?
no smog here and no problems with the cops and a loud exhaust.... so i'm going to go straight pipe all the way back. loose the cat on my eco (i dont know if it is even there anymore....)
any other sugestions on the exhaust...
the only thing i think that will be hard to bend/ make is the real curvy section over the rear axle.. am i right?
_________________
united states recessions
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
January 23, 2005, 04:43:32 pm
Dr. Diesel
Authorized Vendor
new exhaust
January 23, 2005, 04:43:32 pm »
farkman's the expert on this subject. Peter?
January 24, 2005, 06:01:30 pm
farkman
new exhaust
January 24, 2005, 06:01:30 pm »
Expert, not really Dr. Diesel :lol: , a novice at most.
Mainer
I sent you a PM but I didn't answer all your questions.
I made the exhaust using 2.5" 90 degree mandrel bent elbows and 2.5" tubing. These were all .065" wall stainless steel. I cut the elbows into 45 degree bends which I used on nearly all the curves. The pictures I'm going to send you should give you an idea of what the downpipe looks like. The curvy section over the rear axle was somewhat difficult to line up, including the hangers. I didn't get it right though. Between ~1100-1150 rpm the exhaust vibrates enough to hit the body to make an annoying rattle. Other than that it came out pretty good and I picked up about 2 mpg in the process.
Peter
January 24, 2005, 06:17:25 pm
mk1vdub
new exhaust
January 24, 2005, 06:17:25 pm »
hey farkman,
I'm in the process of doing a downpipe for my A1 with A2 TD engine, I'd love to see the pics of your exhaust, my email is
[email protected]
, or pm them to me or post 'em up for all to see which ever works for you
TIA
1983 mk1 golf GTD
1980 mk1 scirocco Gli, in bits, in the garage, awaiting full restoration
January 25, 2005, 08:08:52 pm
1985JettaTD
new exhaust
January 25, 2005, 08:08:52 pm »
I too am interested on how you made your down pipe and the rest of the system. I am trying to make a system for my 1.6TD 85 Jetta and i am not having very good luck with it. if you could PM me or sent the pics to me at
[email protected]
that would be soooooo sweet.
Thank you for all the help!!!! JVG
new exhaust
