Author Topic: Looking for glow plug relay info  (Read 3134 times)
January 19, 2005, 09:34:53 pm
jackbombay
  • 599
« on: January 19, 2005, 09:34:53 pm »
I'll need to set up a glow plug relay when I swap the TD into my quantum. The Audi TD is a 5 banger, but I would imagine a 1.6/1.9 GP relay could handle the extra GP.
  So where could I get one? Is a wrecker my best bet?
  What does the GP relay need for info? Coolant temp and power in and out?
Reply #1January 21, 2005, 07:56:43 pm
jackbombay
  • 599
« Reply #1 on: January 21, 2005, 07:56:43 pm »
Well there are fast and slow glow plugs appearantly, since there are already GPs in the motor how do I know what type they are so I can get the correct GP relay?
Reply #2January 22, 2005, 02:22:03 am
Patrick
  • 1034
« Reply #2 on: January 22, 2005, 02:22:03 am »
Part number on the glow plug should tell you. I saw a listing somewhere (this site?) that said which one was which, and what number the matching relays were. Good luck finding it! :roll:
Reply #3January 22, 2005, 10:13:07 am
janb
  • 167
« Reply #3 on: January 22, 2005, 10:13:07 am »
general rule of thumb  "brass is fast" (theaded end of plug)    silver   is slow(aluminum)  but, I recently got some 'stainless' end fast ones;  also the tips (heat element) of fast are usually tapered, but slow are full dia to rounded tip
I suggest using a starter 'push button' in place of a relay, and an indicator light from buss bar, at least you will know when it's working   8} :?
The Stealth Rabbit
VW-d's are forever
