Author Topic: FS 93 Passat turbodiesel not running needs head loaded $1100  (Read 5917 times)
June 23, 2007, 07:51:54 pm
bigblockchev
  • 271
I have too many projects & this one needs to go it is a 1.9L turbodiesel. I did the rings and bearings & timing belt on it but it  needs a head. Has power sunroof and AC, 5 speed. Compression was very good before it overheated. Body has no rust & is basicly straight. Car needs a bit of TLC but has potential. Quite rare. reply to danmdanm at gmail dot com
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #1June 25, 2007, 07:38:29 pm
Cheesetoast
  • 285
« Reply #1 on: June 25, 2007, 07:38:29 pm »
how many km's, how's the transmission?
Reply #2June 25, 2007, 09:41:39 pm
bigblockchev
  • 271
passat
« Reply #2 on: June 25, 2007, 09:41:39 pm »
470kms, transmission seems fine, block has very little wear, head seems to be leaking into the precup area. Bought the car 3 months ago as a barely running project repaired several stripped exhaust studs which required pulling the motor. tested compression at 550psi on rear and 500 on front cyls should have known something was wrong much too high, head gasket blew & overheated turned out to be a 1 notch gasket , I replaced with a 3 notch gasket but head was leaking by now. rest of car is avg condition but worth saving. priced out heads today $725 bare ouch!! if you need anymore info let me know  are you in the lower mainland I seem to recall that username on the DOV board Cheers Dan
2000 Jetta TDI
Reply #3June 25, 2007, 09:51:58 pm
Cheesetoast
  • 285
« Reply #3 on: June 25, 2007, 09:51:58 pm »
yes i just replaced the head on mine, OEM fully rebuilt, complete head is $1350 after core charge.
Reply #4June 26, 2007, 05:39:32 am
Re: passat
« Reply #4 on: June 26, 2007, 05:39:32 am »
Quote from: "bigblockchev"
that compression is really good (for cold starting...)  did you measure piston protusion at all, or just stick on the 3 notch gasket?  winter starts will be a bit rougher if the motor specs call for a 1 notch...
Dave at pp said he could create a killer head for around $1500.   how much do you want for the car?
Reply #5June 26, 2007, 06:42:35 am
bigblockchev
  • 271
passat
« Reply #5 on: June 26, 2007, 06:42:35 am »
Yes it started exceptionaly well even with a weak battery. I did not measure the piston protrusion, I was searching for the most reliable scenario after the head gasket failure and figured the thickest gasket would provide that. Asking $1100 for the car. I am pretty sure that the previous owner used the wrong gasket resulting in the too high compression and compromised reliability. Cheers Dan
2000 Jetta TDI
Reply #6June 26, 2007, 01:04:20 pm
Re: passat
« Reply #6 on: June 26, 2007, 01:04:20 pm »
well if the pistons and valves didn't smack, i'd say that he probably used the right one.
didn't clue in on the price in your post subject title  :oops:  $1100 is pretty cheap man.
Reply #7June 26, 2007, 03:34:36 pm
bigblockchev
  • 271
head hopefully coming
« Reply #7 on: June 26, 2007, 03:34:36 pm »
I am in negotiation for a head for this car so hopefully it will be a runner. Will repost when back together. Thanks guys
2000 Jetta TDI
Reply #8June 28, 2007, 10:14:57 pm
bigblockchev
  • 271
« Reply #8 on: June 28, 2007, 10:14:57 pm »
trying imageshack w'ell see http://img412.imageshack.us/img4]passat]http://img412.imageshack.us/my.php?image=pdr0320si8.jpg][IMG]http://img412.imageshack.us/img4]passat pic http://img217.imageshack.us/img]http://img217.imageshack.us/my.php?image=pdr0321vn1.jpg][IMG]http://img217.imageshack.us/img passat 2
      http://img217.imageshack.us/my.php?image=pdr0322uo5.jpg]
      http://img245.imageshack.us/my.php?image=pdr0323cc1.jpg]
      http://img245.imageshack.us/my.php?image=pdr0324xs5.jpg]
      http://img245.imageshack.us/my.php?image=pdr0325sh4.jpg]
      not too good at pics but here you are
      Cheers Dan
2000 Jetta TDI
Reply #9June 28, 2007, 10:17:18 pm
bigblockchev
  • 271
« Reply #9 on: June 28, 2007, 10:17:18 pm »
Well that didn't work
2000 Jetta TDI
Reply #10June 29, 2007, 06:58:41 am
« Reply #10 on: June 29, 2007, 06:58:41 am »
      Cheers Dan
Cheers
