Author Topic: '81 Diesel Caddy Enhancements  (Read 5879 times)
January 19, 2005, 08:58:19 am
VWRacer
  • 649
« on: January 19, 2005, 08:58:19 am »
I'm looking at a buying an '81 diesel caddy (that's in very nice shape), and got to wondering about how well they respond to suspension and engine upgrades? (The only reason I've hesitated is that it doesn't have a/c - kind of a must hear in Cali.)
I had a diesel caddy back in the day, and my recollection was that it was grossly underpowered and too softly suspended. Can a Mk1 GTI-type suspension be retrofitted? And I'm confident that upgrading the engine to TD would be a big help. Suggestions...ideas?
Thansk! Stan
Stan
C-Sports Racer
Reply #1January 19, 2005, 12:14:23 pm
« Reply #1 on: January 19, 2005, 12:14:23 pm »
if money isnt an issue, you can do practically ANYTHING :D
if its non turbo.. and the engine is old.. you might have around 48 HP to work with.. (running a/c will make that drop to about 42 HP or so with compressor and alternator draw)  I know a guy who put a 300 amp alternator into his diesel car-it had 48HP and would stall at idle lol...
but yes if money is no issue, buy the stiffer coils and different parts you need and it should work.  Maybe someone on this forum has inexpensive tricks for you though :D
Reply #2January 19, 2005, 12:31:49 pm
mk1vdub
  • 93
« Reply #2 on: January 19, 2005, 12:31:49 pm »
hey, take a look here  click for all your caddy needs :wink:
if you can't find out info on what you want to do there then it probably can't be done....
1983 mk1 golf GTD
1980 mk1 scirocco Gli, in bits, in the garage, awaiting full restoration
Reply #3January 19, 2005, 12:51:28 pm
VWRacer
  • 649
« Reply #3 on: January 19, 2005, 12:51:28 pm »
Cool...thanks for the link! :D
Stan
C-Sports Racer
Reply #4January 19, 2005, 03:53:37 pm
« Reply #4 on: January 19, 2005, 03:53:37 pm »
like i said... if you have money.. it can be done.. lol
MONSTER GARAGE vw diesel caddy swap cummins V8 engine!!! LOL
Reply #5January 19, 2005, 06:45:40 pm
« Reply #5 on: January 19, 2005, 06:45:40 pm »
The part that's a bummer about caddys is the rear suspension, it has a solid axle with leaf springs, which are great for hauling loads but not so good for handling. (although it will out handle most any other truck, it IS a VW after all...)  I have no idea if it is possible to swap the torsion beam suspension on a Caddy.  I'd be pretty cool if you could, though.  :)
84 Scirocco 8v
00 Camaro L36 M49
Reply #6January 20, 2005, 04:57:54 am
Mikeyworks
  • 260
    • http://www28.brinkster.com/mikeyworks/
« Reply #6 on: January 20, 2005, 04:57:54 am »
I have my '81 Diesel Caddy (which unfortunately at this time is DOA), and it had the 1.6TD in it. I would very pleased with the power of the TD, to the point that I sold my V6 Ford Ranger b/c the Caddy was much more fun!!!!
As for suspension, you can always retrofit any MK1 front suspension on there. As for the rear, if you want to drop it, you can just flip the leafs to the underside of the axle. Or if you want to jack it up, check out Roger's pages...here...this includes adding a leaf or two, or even shackles if you really want to go up!!!
I am in the process of putting a 1.9TD into my Caddy...that should be more power than I need!!!!
Mikey
Reply #7January 20, 2005, 10:02:02 am
diffdude
  • 39
caddy
« Reply #7 on: January 20, 2005, 10:02:02 am »
Quote from: "lord_verminaard"
The part that's a bummer about caddys is the rear suspension, it has a solid axle with leaf springs.
 That camaro you have does prity good with a solid axle? I have a 69 camaro with rear leafs and it does just fine at the track.
81 caddy 1.6 td, 2.5" turbo back, snow performance water/meth injection, and all the other usual mods.
Reply #8January 20, 2005, 10:12:59 am
diffdude
  • 39
« Reply #8 on: January 20, 2005, 10:12:59 am »
vwracer, I have a 81 caddy i am working on now. I bought a 88 cabriolet on craigslist for 150.00 in concord and all the suspention bolted on. The ac stuff bolts on to except the motor brackets.
Reply #9January 20, 2005, 04:49:27 pm
Re: caddy
« Reply #9 on: January 20, 2005, 04:49:27 pm »
Quote from: "diffdude"
Heh, my Camaro has coil springs, lower control arms, torsion bar, track bar, and a rear swaybar, all stock.  It still doesnt handle worth a crap.  :P
Just messin with ya- ;) but the Camaro was designed to handle well on the street, the Caddy was designed with more utility in mind than handling.  It still has the basic VW front suspension design though, which is what makes it handle like a true German car should.  :D
It's pretty sad when the 20 year old springs on my Scirocco are tighter than the springs on my 5 year old Camaro, which weighs almost twice as much.  :roll:
84 Scirocco 8v
00 Camaro L36 M49
P.S. the Camaro is getting sold in the springtime.  :P
Reply #10January 20, 2005, 07:13:11 pm
diffdude
  • 39
camaro suspention
« Reply #10 on: January 20, 2005, 07:13:11 pm »
Its prity bad when american sports cars are built around ride comfort, not all out performance.
