S-PAutomotive.com
Author Topic: how to build injector tester or where to get one?  (Read 1905 times)
June 20, 2007, 07:07:59 am
knowtwodrugs
  • 46
« on: June 20, 2007, 07:07:59 am »
I saw one on Ebay a few weeks ago, I should've grabbed it up when I had the chance.  Does anyone know if there's a how to or any companies that make them?
- Ayrer Performance & Machine -
Performance Valve Jobs, Rod Resizing, Crank Grinding & Polishing, Cam Bearings, Block Squaring, Block Boring, Head Milling, Etc...
 "Complete Engine Design For The Type Of Racing That You Do!"
609-835-0779
Over 25 Years Experience
Reply #1June 20, 2007, 10:26:33 am
  • 3255
    • My collection of HOWTOs
« Reply #1 on: June 20, 2007, 10:26:33 am »
Having built one myself let me add my voice to the chorus of warnings you'll find in that post:
WARNING WARNING WARNING:  you are dealing with extremely high pressures.  Pressures that can maim, blind, and kill.
- use only high pressure hydraulic fittings throughout.  If you're in the plumbing isle you're in the wrong place.
- wear safety equipment at all times... goggles and gloves.  Diesel at that pressure can penetrate skin very easily, and often amputation is the only cure.
- at that pressure diesel is often a fine mist and highly flamable (duh!)... not a good place to be puffing on a stogie.
Reply #2June 20, 2007, 10:48:05 am
bevboyy
  • 200
« Reply #2 on: June 20, 2007, 10:48:05 am »
This is truly worth a sticky :wink:
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #3June 20, 2007, 08:27:28 pm
biojetta
  • 16
« Reply #3 on: June 20, 2007, 08:27:28 pm »
I have a factory built one (meaning not homemade) in my garage. Haven't had time lately to use it though.
Tylor
'85 Jetta GL diesel
'82 Datsun diesel
'04 Jetta TDI Sport
'02 Dodge Cummins
