Author Topic: 1.9TD turbo oil return lines  (Read 3043 times)
January 16, 2005, 09:37:32 pm
MK3 GTD
  • 48
« on: January 16, 2005, 09:37:32 pm »
I know earlier 1.9TDs came with a different turbo other than the k03 what i want to know is if it uses an oil return line that directly fits the K24 turbo and has the banjo fitting to return to the block not the oil pan.
1996 Golf 1.9TD
1984 Rabbit 1.6TD
1987 Jetta Coupe 1.6D
Reply #1January 17, 2005, 10:13:53 am
asau
« Reply #1 on: January 17, 2005, 10:13:53 am »
yes the oil return goes from the turbo(attached by a banjo) to the block(another banjo). let me see if i can find a pic
Reply #2January 17, 2005, 06:26:08 pm
MK3 GTD
  • 48
« Reply #2 on: January 17, 2005, 06:26:08 pm »
let me restate that,
i know that it goes to the block, i need to know if there is a oem return line available that goes to the block but has the bigger turbo-end flange used on the k24.
i know its not hard to get one made, im just checking my options
1996 Golf 1.9TD
1984 Rabbit 1.6TD
