General Information
Troubleshooting
1.9TD fan problem
Topic: 1.9TD fan problem (Read 7358 times)
January 16, 2005, 09:49:54 am
Pfhettinga
1.9TD fan problem
January 16, 2005, 09:49:54 am »
Hey
I have a 1994 golf TD and the cooling fan in front of the radiator comes on as soon as I turn the key and continues to stay on. I was wondering if any one else has had this problem or know how to fix it.
thanks in advanced
January 17, 2005, 10:40:21 am
Pfhettinga
1.9TD fan problem
January 17, 2005, 10:40:21 am »
any one if it could just be a bad sensor?
January 17, 2005, 11:06:13 am
ricosuave
1.9TD fan problem
January 17, 2005, 11:06:13 am »
dumb question, but is the a/c on?
Now: 00 2dr Golf TDI, 03 Jetta Wagon TDI, 02 2500HD Duramax -
Then: 69 SC Transporter, 84 Rabbit GTI, 87 Fox GL, 91 Golf IDI, 96 Passat Wagon TDI, 97 Jetta IDI -
"Everything I save by driving diesel I put back due to poor German engineering and crappy Mexican workmanship!"
January 17, 2005, 06:03:59 pm
Pfhettinga
1.9TD fan problem
January 17, 2005, 06:03:59 pm »
don't have A/C
but im looking at a wiring Diagram and wondering if it could be a bad thermal switch / relay or the collant FC control module
January 18, 2005, 12:24:54 am
AC always on
January 18, 2005, 12:24:54 am »
Defroster on?
It kicks on the AC too right?
January 18, 2005, 04:20:14 am
Pfhettinga
Re: AC always on
January 18, 2005, 04:20:14 am »
Quote from: "fatmobile"
Defroster on?
agian, my car doesn't have A/C
but with car that have A/C I belive deforster does use the A/C when it's above a certian temprature
January 18, 2005, 09:53:10 pm
MK3 GTD
User+
1.9TD fan problem
January 18, 2005, 09:53:10 pm »
Hey Peter, try the thermo-switch first, its the brass sensor that is screwed into the radiator under the upper rad hose, this can cause the problem and is much cheaper than the control module.
Make sure you have the new one ready to screw in right as you get the old one out since coolant will come pouring out the hole.
1996 Golf 1.9TD
1984 Rabbit 1.6TD
1987 Jetta Coupe 1.6D
January 19, 2005, 06:06:45 pm
Pfhettinga
1.9TD fan problem
January 19, 2005, 06:06:45 pm »
Thanks Eric, I'll give that a try 1st and see if solves things
General Information
Troubleshooting
1.9TD fan problem
