Author Topic: DIY Adjustable Cam Pulley  (Read 6024 times)
January 14, 2005, 08:45:08 am
VWRacer
  • 649
« on: January 14, 2005, 08:45:08 am »
DISCLAIMER: Do this at your own risk. I do not advocate it. In fact, I discourage you from trying it, as I suspect that there are better approaches to achieving better high-RPM airflow. Nonetheless, my respect for you, my fellow gearheads, forces me to share what I know.
Okay, disclaimer aside, it turns out that I have these pics with me on my laptop, so I am loading this infor up now, rather than having to wait until I get home this weekend.
Converting a fixed-timing cam pulley to an adjustable one is mechanically simple, but it can be somewhat challenging to calculate just where to drill the holes.
Take a look at the first photo. Notice that there are three sets of holes drilled in the adjustor plate, plus three slotted holes. At lower center, the holes are marked in degrees advanced, 2, 3 and 4 degrees. At upper left three more unmarked holes are for the same degrees retarded. On the right edge, three holes mark 1 degree retarded, straight-up, and 1 degree advanced. Notice that the set-screw is in the straight-up position.
Now take a look at the photo below. This is of the backside of the pulley, and shows the OEM timing notch. One can also see the set-screw in the straight-up hole.
To advance the cam to, for example, two degrees advanced, loosen the three slotted screws and remove the set-screw. Rotate the outer ring until the hole behind the 2-degree hole is perfectly lined up with the 2-degrees advanced hole, and reinstall the set-screw INTO THAT HOLE (you can see that the hole is not prefect aligned - you will only have to move the outer pulley, well, 2 degrees! ;)). Tighten the slotted screws. [You will now have to re-time the injector pump, but we are only discussing how to adjust the cam's timing.]
To actually make the pulley, my friend Tom Nelson, who originally built this engine, started by drilling and tapping the three sets of 3 holes a convenient distance apart on three of the pulley's flanges, plus the holes for the slotted screws (yes, I know the screws are not slotted, but you know what I mean... ;)) Next, he prepared the .050" aluminum plate by cutting a round piece the right diameter and cutting the center hole and the 6 mounting holes (near the center). Tom then drilled the hole for the zero, or straight-up position.
By mounting the plate to the unmolested cam pulley, Tom reached in through the holes to mark the backside of the plate. This gave him the positions of the holes. He then offset the plate the correct distance and drilled the 8 remaining timing holes. To do this you can use a straight edge and protrator, or calculate the distance using some basic high-school trig, or eyeball it by dividing the number of teeth on the pulley into 360 to discover how many degrees per tooth there is on the pulley, then swag the distance to offset. I don't recommend this technique, but it has been used by DIYers since time-immemorial. ;)
Finally, insert a hacksaw blade into each lightening hole and cut through the flanges. Debur the cuts 9see lower photo above). Now the cam pulley's outer section is floating with respect to the inner and you are ready to bend valves...er uh, I mean achieve new heights in diesel RPM and power! ;)
Alternatively, if this all makes your head hurt, print out this description with the photos and take it to your favorite machinist. Explain to him what you want and be prepared to pay him for several hours of shop time. Yet another potential source is to talk to one of those places that makes adjustable sprockets for gassers and ask them if they would modify your diesel cam pulley in the same way. Sorry, Tom is not available.
Sorry this is so rushed, but I have to dash to the airport. By the time I get home I trust that some of the 40-pound brains here will have spotted and corrected the errors I no-doubt made. ;)
Stan
C-Sports Racer
Reply #1February 22, 2005, 11:03:37 am
steve
  • 70
« Reply #1 on: February 22, 2005, 11:03:37 am »
That's pretty cool.  Is this for 1.6L or TDI?  It will work on either I guess but I'm not famillair with the 1.9
Since the 1.6 has no key way between the cam pulley and cam, I advanced the cam on my 1.6L TD by just cheating the normal adjustment procedure.  I figured out how many degrees each tooth is on the flywheel and instead of lining the crank up with the TDC mark, I rotated it backwards in relation to the normal engine rotation by X number of teeth.  Then tighten down the cam pulley bolt.  Cam is now advanced.
Take me back to Colorado...........  84 Quantum 1.6L TD 470K miles, 2003 Jetta TDI 95K
Reply #2November 14, 2005, 08:52:33 pm
ancient
advanced cam
« Reply #2 on: November 14, 2005, 08:52:33 pm »
HI, what's the adventage of advenced cam?
Reply #3November 15, 2005, 04:57:07 am
steve
  • 70
« Reply #3 on: November 15, 2005, 04:57:07 am »
Camshaft timing affects engine performance like any timing event in the engine can.  Racing engine builders know this very well.  You can get a "degree wheel" and acomplish this on many engines with an offset keyway.
Advancing the camshaft tends to lower the power band and decrease the high rpm performance.  and vice versa.
Reply #4April 12, 2006, 01:36:44 pm
fspGTD
  • 1529
« Reply #4 on: April 12, 2006, 01:36:44 pm »
Moved to IDI power enhancement section.  This thread is very interesting and useful, but not exactly frequently asked.
Jake Russell
Reply #5April 12, 2006, 09:49:00 pm
hillfolk'r
  • 1532
« Reply #5 on: April 12, 2006, 09:49:00 pm »
iwould think since our diesels have no key,,y do u need an adjustable gear??do it  at the camlock tool,,,,,,,
Throttle cables ftw
Reply #6April 12, 2006, 09:51:04 pm
935racer
« Reply #6 on: April 12, 2006, 09:51:04 pm »
Yeah I have tried the same thing, why go through all that hgassle when there is no keyway you can just spin it on the cam end.
Reply #7April 13, 2006, 12:12:28 am
fspGTD
  • 1529
« Reply #7 on: April 13, 2006, 12:12:28 am »
I'm guessing this could be useful if you swapped in a gasser cam.
Jake Russell
Reply #8April 14, 2006, 05:53:34 pm
hillfolk'r
  • 1532
« Reply #8 on: April 14, 2006, 05:53:34 pm »
yea true jake,,,,,,didnt think of that,,,,, :idea:
Throttle cables ftw
