Which fuel filter to use???1.9TD
Topic: Which fuel filter to use???1.9TD (Read 4507 times)
January 13, 2005, 09:57:53 pm
Topherdiesel
January 13, 2005, 09:57:53 pm »
I am reading all these terrible things about the fuel filters...so what do I do, I am due for one, long overdue!
Which one do I get?
January 13, 2005, 10:22:09 pm
ricosuave
January 13, 2005, 10:22:09 pm »
its made by bosch. and if you can wait until morning, ill get the # for you.
any crappy tire or napa should have it for ~$25
rico
Now: 00 2dr Golf TDI, 03 Jetta Wagon TDI, 02 2500HD Duramax -
Then: 69 SC Transporter, 84 Rabbit GTI, 87 Fox GL, 91 Golf IDI, 96 Passat Wagon TDI, 97 Jetta IDI -
"Everything I save by driving diesel I put back due to poor German engineering and crappy Mexican workmanship!"
January 14, 2005, 01:59:59 pm
srivett
January 14, 2005, 01:59:59 pm »
The 1.6D OEM and Wix/Carquest filters go for 35CDN. Both mine and my brothers cars had fuel filters with somewhere around 200K km on them. I have receipts for absolutely everything except the fuel filter. From now on I'll be changing it something like once a year or 50K, or whenever I get nervous. That is, unless I start running biodiesel. Then I'll buy a box of them.
Cheers, Steve
1992 1.6D Golf - 412K km
Mint except for chipped paint, no rust
January 15, 2005, 12:09:40 am
janb
January 15, 2005, 12:09:40 am »
you might want to 'downgrade' to a pre '85 spin on Fuel filter, they are ~$7USD, I use them on both my 1.9's
The Stealth Rabbit
VW-d's are forever
January 15, 2005, 05:24:59 am
Topherdiesel
January 15, 2005, 05:24:59 am »
How the heck would I do that?
January 15, 2005, 04:41:36 pm
asau
January 15, 2005, 04:41:36 pm »
i downgraded on my 1.9 also, a $7 filter is more appealing than the $35 one.
January 15, 2005, 07:58:45 pm
Cheesetoast
January 15, 2005, 07:58:45 pm »
i think mines due for replacment, arn't they supposed to be done every 20,000km?? would it affect milage if it needed doing?
1993 Golf 1.9TD
http://members.shaw.ca/adowler/
January 15, 2005, 10:55:26 pm
janb
January 15, 2005, 10:55:26 pm »
Quote from: "Topherdiesel"
get a 'spin-on' housing bracket off a junker '76 - 84, bolt it to your strut tower, screw on a filter element and go
If you have a filter 'warmer' line, just bypass and send to tank return
The warmer is a good idea, but not necessary
The Stealth Rabbit
VW-d's are forever
January 16, 2005, 02:26:09 pm
andy2
January 16, 2005, 02:26:09 pm »
The Bosch part# is 0 450 906 172 and there are two other numbers on the box N 6172 and 74003.Some people here would probably know what years or application this filter was used,Its probably going to cost less do the same job and cause you less grief.This filter is not a thread on its shorter than the 1.9 one but it fits in the same bracket so the only change is the no return feature so you take the plastic valve/connector out and connect the two hoses thats all. However If there is no issues with the plastic fitting then just stick with the 1.9 filter.That updated fitting cost $50+ :? from the stealership and I'm not sure if anyone else makes them :?: so the old fitler is a welcome changeover.If and when you do find the filter buy a couple as they may not be available much longer I don't know.I have a couple at my work so some other places must have some collecting dust on the shelf also :wink:
January 16, 2005, 02:30:19 pm
andy2
January 16, 2005, 02:30:19 pm »
the box has a Ford/VW application on it if that helps any.
