Author Topic: Changing from N/A to turbo motor?  (Read 10431 times)
May 25, 2004, 07:20:37 pm
Hammy
  • 169
« on: May 25, 2004, 07:20:37 pm »
Hey guys;
 I just bought a turbo motor, runs great. Anyways, has anyone got any tips, advice or anything at all to comment on please send it this way.
 It looks like a fairly easy swap. I do have a question though. There is some sort of 2 wire connector and a sensor in the smaller rubber intake tubing, that  comes off of the main duct, and goes to the round plastic thing on the side of the intake (not the turbo). What is this round plastic thing, an EGR valve or something? And what is this sensor, a heater maybe? It has key on battery power. Just not sure what it is.
 Will my clutch work from my N/A motor, or do I need a new one? I just did it a month ago, I would hate to have to change it.
 That's all I can think of for now. Any help would be appreciated.
 Thanks;
 Moonstone (Jason)
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #1May 28, 2004, 07:38:40 pm
Hammy
  • 169
Motor swap
« Reply #1 on: May 28, 2004, 07:38:40 pm »
Well guys, it took a little bit, and a few trips to the parts store, but it's all done! So far so good. I seem to be having a little trouble getting the air out of the main line. I can't find any leaks, (before the pump) . The doner car sat far a while, and I'm wondering if the inj. pump could cause this air, or only a leak somewhere? Also, are the turbo injectors the same as the N/A ones? They look the same, and I have a noisey one. Otherwise it seems to run fairly well once you pick up the idle a bit. Any suggestions or comments would be great. Keep up the good work!
Moonstone (Jason)
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #2May 29, 2004, 07:44:53 am
caddywompus
  • 27
    • http://www.greaseworks.org
« Reply #2 on: May 29, 2004, 07:44:53 am »
Turbo injectors and NA injectors are the same except for the breaking pressure: 130 bar NA, 155 bar turbo.  This makes a significant difference in injection timing/performance and it is inadvisable to mix the two.
Hope this helps,
Justin
82 Vanagon Westphalia 1.9TDI (1Z)
96 Passat Wagon 1.9 TDI
Reply #3May 31, 2004, 05:49:48 am
Hammy
  • 169
« Reply #3 on: May 31, 2004, 05:49:48 am »
I'm glad you mentioned this, I was just going to swap them out with the N/A ones, LOL. Thanks for the info Caddy, it's great to get help like this guys, thank-you.
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #4June 01, 2004, 09:09:35 am
BlackTieTD
  • 1512
« Reply #4 on: June 01, 2004, 09:09:35 am »
i suspect my engine has a noisy injector as well... a ticking became noticable when we advanced the injection pump timing. we suspect its breaking pressure is a little low, 1st cylinder injector.
is the ticking you have the loudest at idle, and when you're getting heavy on the throttle at lower rpms? it gets a little quieter as the engine warms up...but is basically drowned out at high rpm (i have no resonators/mufflers, so maybe thats why it gets drowned out).
hoping to swap in a used injector this week or next and pinpoint the problem.
i see you're from ontario, how far from hamilton? if you need a spare injector to swap in, the doc might be able to help!
Reply #5June 01, 2004, 06:58:40 pm
Hammy
  • 169
« Reply #5 on: June 01, 2004, 06:58:40 pm »
BlackTie;
 I have exactly the same noise you are talking about, in the same way. I got my injectors to stop leaking between the two halves, by using a little teflon tape on them, but it didn't help the noise. I'm hoping that it may clear up on it's own, seeing that the doner engine (car) sat for so long, but I doubt it.
 I live in a small town called Moonstone (hence the name), which is about 1 hour North of Toronto. Hamilton would be about a 2 hour tour for me.
 Where are you residing?
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
Reply #6June 03, 2004, 06:43:27 am
BlackTieTD
  • 1512
« Reply #6 on: June 03, 2004, 06:43:27 am »
i'm in kitchener, hamilton is about 45 minutes from me. toronto is an hour away.
keep us posted about that noise... i'd like to get to the bottom of it. i'll let you know what happens when i replace the injector... see if that clears it up.
Reply #7June 03, 2004, 07:48:59 am
Hammy
  • 169
noise
« Reply #7 on: June 03, 2004, 07:48:59 am »
It's funny it seems to come and go, even while idling. You can hear it fading and out without touching the throttle.
 If anyone is interested, this weekend is the automotive flea market in Oro (Burl's Creek) Ontario. It is 15mins. North of Barrie on hyw 11, turn off at the exit for Barrie  Speedway. (I forget which line this is.)
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
