Author Topic: Redline water wetter??  (Read 3661 times)
May 30, 2007, 04:41:42 pm
subsonic
  • 1836
« on: May 30, 2007, 04:41:42 pm »
Saw this on sale the other day. Read a bit of litature on it. Anyone here using it?  Does it really work?
Reply #1May 30, 2007, 07:15:51 pm
« Reply #1 on: May 30, 2007, 07:15:51 pm »
It works, but it works best on straight water. It will mildly reduce temps in an anti-freeze mixture, I think 5-10 degrees depending on mixture.
Reply #2May 31, 2007, 12:29:10 am
BellCityDubber
  • 251
Re: Redline water wetter??
« Reply #2 on: May 31, 2007, 12:29:10 am »
Quote from: "subsonic"
Most bigger commercial/heavy duty diesels run SCA (supplemental cooling additivies) as recommended by the manufacturer...
I've always sworn by water wetter... I've noticed a difference.. and I run a more water than coolant mixture in the warmer months... it seems to work excellent.
Reply #3June 01, 2007, 01:05:35 am
HarryMann
  • 170
« Reply #3 on: June 01, 2007, 01:05:35 am »
Some Subaru owners use it as they can have a tendency to air-pocket within the heads, and they don't like that, at all, at all..
Reply #4June 04, 2007, 03:24:58 pm
Caddyman
  • 7
« Reply #4 on: June 04, 2007, 03:24:58 pm »
Works great. I use it in all my vehicles and in my liquid cooled computer. What is really neat to watch is the affect after putting it in the system, smooths flow out and quiets the pump down (along with decreased temperatures).
Reply #5June 04, 2007, 03:43:09 pm
MaxHedrm
  • 114
    • blog
« Reply #5 on: June 04, 2007, 03:43:09 pm »
Just be careful what coolant you run it with. It isn't compatible with everything.
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #6June 04, 2007, 03:56:16 pm
xud9te
  • 88
« Reply #6 on: June 04, 2007, 03:56:16 pm »
I heard from a friend who used to work for a chemical testing company that dishwasher cleaning tablets were the same thing as water wetter!!
Havent tried it though..
Reply #7June 04, 2007, 08:23:33 pm
« Reply #7 on: June 04, 2007, 08:23:33 pm »
Yes, I have heard that rinse aid, like Jet Dry, work similarly.
Reply #8June 05, 2007, 05:22:47 am
red64chevelle
  • 67
« Reply #8 on: June 05, 2007, 05:22:47 am »
I have used water wetter on my old EcoDiesel, Chevys, and dirt bikes.  It has worked for all of them.  Rhode Island does not get as cold as it does further up north, so I don't have to run as high of a coolant ratio, so it might help the southern people more than the northern people.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
1964 Malibu Convertible
