Author Topic: It's alive!!!! Kinda...  (Read 2346 times)
May 21, 2007, 08:35:36 pm
Black Smokin' Diesel
  • 656
« on: May 21, 2007, 08:35:36 pm »
For the first time in a month, my TD engine ran (albeit only for a few minutes).
I had to replace the head so I took the opportunity to do the crank, cam and intermediate shaft seals, replaced the shifter bushings (really easy when the head is off), replaced the oil pan with a custom made baffled pan, installed a crank scraper and fixed that leaky oil cooler/heat exchanger.
The head got mercedes injectors (135bar), new glow plugs, new lifters, slight P&P, new gaskets and a rebuilt K24 (thanks to burn_your_money for the working wastegate and compressor/turbine wheels). I wish I could have done a cylinder hone with new rings but that was out of my budget. Anyway the cylinder walls looked good and compression was good.
I used the 1.9TD HG with new timing belt and tensionner. I also got my dirty hands on an aluminum thermostat housing from an early MK2.
So today after filling up with 10w30 synthetic oil and a 65/45 mix of coolant, I tried to start the engine.
Turns out I had to retime the pump and fart around rotating it to get it to fire. Mind you that I don't have the dial indicator to do it properly :( Now it runs but it's really rough, smokes like a steam engine and sounds like a big rig :lol: There are small leaks around the injectors and oil return line on the turbo (what a *** to install :? ). They should be taken care of tomorrow.
All these symptoms are IMO related to timing. I'll be going to a VW garage this week to get it timed to NA specs since the injectors are 135bar and not 155bar units. I'll also have the pump propery adjusted, idle is a bit high.
Now I noticed the timing belt was wandering a bit on the pulleys (about 2mm) and that the intermediat shaft pulley was making a nice cut in my brand new TB!!! Anyone knows why it's wandering like this? All the pulleys seem to be aligned. I read a short time ago that the later intermediate shaft pulleys weren't "grooved" like the early ones. I happen to have one of these flat IS pulleys. I think it might solve my problem, or at least stop my TB from being cut like this.
For this reason and the leaky bits, I didn't take the car for a ride. I did notice the engine was heating up pretty fast (1/4 of the gauge in a few minutes at idle). Could this be a side effect from the bad timing?
Here's a picture of the car the day I bought it.
Reply #1May 21, 2007, 10:24:56 pm
« Reply #1 on: May 21, 2007, 10:24:56 pm »
Yup, everything you've described could be associated with leaks and expecially timing... my suggestion: don't waste any more of your time until those two are looked after.  Good chance things will look up !!
Reply #2May 22, 2007, 07:37:15 am
  • 656
« Reply #2 on: May 22, 2007, 07:37:15 am »
Quote from: "Vincent Waldon"
Thanks! Leaks will be taken care of today and I'm having the car professionnaly timed in a VW shop thursday.
I'll be replacing the IS pulley with the non-grooved one I have today as well. I'll also take a few pictures of the engine bay and car as it's a bit different than when I bought it, just for fun :P
Reply #3May 22, 2007, 09:45:50 pm
  • 656
« Reply #3 on: May 22, 2007, 09:45:50 pm »
Got the leaks fixed (I hope) and replaced the intermediate shaft pulley. The engine is extremely noisy and has very little power.
I wasn't able to drive it home because of some wiring problem on the battery terminals which I wasn't able to fix because the hood cable thought it would be a good time to snap.
