Author Topic: please help gtd injectors garret t3 installed now smokes  (Read 6650 times)
May 10, 2007, 09:26:03 pm
bustedfoxwagen
  • 31
    • http://www.wagenwerks.net
« on: May 10, 2007, 09:26:03 pm »
ok here is the deal has the stock turbo on my 92 eco diesel installed my gtd nozzels everytime i start it it runs rough and smokes like crazy i drive it a mile and come to a stop idels smooth and no smoke?? any idea what it is?
and whats a safe bost level to run with the t3? ran 23psi on small one runnin 10 now need more  :lol:
pics of install
before and after
my rigged oil return line....
92 eco diesel jetta
Reply #1May 11, 2007, 11:16:47 am
bert
  • 423
« Reply #1 on: May 11, 2007, 11:16:47 am »
Was the T3 brand new? it looks like it,ive got a T3 on my AAZ and it runs 11 psi and it really pulls well,try pump timing,now the injectors are new,they will pop at the right pressure,the old ones probably earlier as they wear,
Bert
Reply #2May 11, 2007, 09:02:11 pm
bustedfoxwagen
  • 31
« Reply #2 on: May 11, 2007, 09:02:11 pm »
Bert
got the t3 and manifold off ebay NOS i was told pump timing also i think its set at 100? i don;t know that number come to mind
92 eco diesel jetta
Reply #3May 12, 2007, 04:52:00 am
subsonic
  • 1836
« Reply #3 on: May 12, 2007, 04:52:00 am »
Dude,
I dig the white walls!!  Did someone pimp your ride :shock:  :lol:  :lol:
I do like them though.
Reply #4May 13, 2007, 07:16:11 am
bustedfoxwagen
  • 31
« Reply #4 on: May 13, 2007, 07:16:11 am »
Any air bubbles in the clear fuel line?
Any pump or injector leaks?
Andrew
i didn't see any bubbles in the clear, well mine use to be now its a hazed brown... and my pump has no leaks, only leak it has is an oil leak cause mu pan is beat to crap.. here is a video of how it smokes the first start up everyday
and yes it does blow smoke rings
edit.
and i just put mu boost controller on!!! and WOW it comes alive after 10psi!!! keeping it a 15 now and i love it, sorry i was excited on how good it pulled
92 eco diesel jetta
Reply #5May 13, 2007, 10:28:22 am
« Reply #5 on: May 13, 2007, 10:28:22 am »
One thought:  did you (or whoever redid the nozzles) pop test them and re-calibrate to 155 bar ???
Reply #6May 14, 2007, 02:21:17 am
vwmike
  • 1158
« Reply #6 on: May 14, 2007, 02:21:17 am »
Is your glow plug system working properly?
Reply #7May 14, 2007, 06:10:00 am
sethyboy85
  • 284
« Reply #7 on: May 14, 2007, 06:10:00 am »
my dad's car blew smoke rings and it was a bad injector, you could feel it when driving every so slightly...
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #8May 14, 2007, 06:18:53 am
Wingaman
  • 7363
    • http://www.dmfdiesel.com
« Reply #8 on: May 14, 2007, 06:18:53 am »
Poptest your injector asap before engine damage.
I got a complete shipment of those nozzles(GTD DNOSD274) the last month and 90% was bad.
I bet a bad nozzles or incorrect installation.
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #9May 15, 2007, 07:27:58 am
bustedfoxwagen
  • 31
« Reply #9 on: May 15, 2007, 07:27:58 am »
what is pop test??? i don't know what that is? when igot my nozzels one was bad the shaft wouldn't slid and the other 3 did, so thry sent me another and it was good,
92 eco diesel jetta
Reply #10May 15, 2007, 07:51:10 am
subsonic
  • 1836
« Reply #10 on: May 15, 2007, 07:51:10 am »
Pop testing is like saying calibrating.  It is describing the test process they use on diesel injectors.  Injectors are supposed to open to let the fuel spray at a specific pressure.  The opening pressure can be adjusted by small shims inside the injector.  They change the tension on the spring.
Pop testing is when they hook up the injector to a device where the the pressure is increased until the fuel sprays out.  A pressure guage will record the breaking pressure.  The injector is then shimmed to bring the opening pressure in line with spec's.  The 1.6td injector spec is 155 bar.
If anyof  the injectors opening pressures are out of spec, they will inject fuel to early or late in the cycle.  That will cause your engine to run like ass.  If you call around to any diesel shops near your house you should be able to find someone to pop test your injectors for a small fee.
Reply #11May 15, 2007, 08:34:40 am
« Reply #11 on: May 15, 2007, 08:34:40 am »
To put it another way...injectors have two main parts:
 - a nozzle which decides how much fuel to inject
-  a biggish spring and a shim that sets the pressure that the nozzle turns on at.
Nozzle:  how much fuel
Spring and shim:  when the fuel is injected, based on pressure
So, you've replaced the nozzles... we're asking if you also had the spring/shim combination checked and re-calibrated as required ? Basically each injector is hooked up to a test bench (some of us have built our own) and checked for the "breaking pressure" (when does the injector open... should be 155 bar according to VW).  If the pressure is wrong (and it often is after a full nozzle replacement) the injector is disassembled, the shim is changed, and the process repeats itself.
While the breaking pressure is being set the nozzle is also examined for the right spray pattern.... if the nozzle is defective or dirty it will be obvious.
Like the previous poster said... a local shop will likely be able to do this for you for cheap or even free.... don't forget to at least buy your new heat shields from them !
Reply #12May 15, 2007, 08:49:44 am
Wingaman
  • 7363
« Reply #12 on: May 15, 2007, 08:49:44 am »
I cannot add anything else hehehhe  :D
Reply #13May 15, 2007, 08:40:06 pm
bustedfoxwagen
  • 31
« Reply #13 on: May 15, 2007, 08:40:06 pm »
wow guys you have been more than helpful and seem to really know your stuff i know mopars like that so if you have them and need some info ill be glad to help  :lol:
92 eco diesel jetta
