Author Topic: What would cause this type of damage?  (Read 2633 times)
May 01, 2007, 08:34:22 pm
« on: May 01, 2007, 08:34:22 pm »
This is a picture of a 1.5l head that I recently purchased. Notice that huge hole in the pre combustion chamber? What could have caused that?
Reply #1May 02, 2007, 07:09:53 am
« Reply #1 on: May 02, 2007, 07:09:53 am »
Thank you Andrew, I kind of figured that is what caused it but thought it would be benificial to post it for everyone to see.
Reply #2May 02, 2007, 10:49:07 am
Mark(The Miser)UK
  • 1557
« Reply #2 on: May 02, 2007, 10:49:07 am »
Could that damage occur if you simply ran a mile with coolant level low? So the alloy was just able to crumble like a Krell door? when faced with monsters of the ID? :mrgreen:
Mark-The-Miser-UK
Reply #3May 03, 2007, 04:10:24 am
Mark(The Miser)UK
  • 1557
« Reply #3 on: May 03, 2007, 04:10:24 am »
Quote from: libbybapa
I suppose, but why would the others looks so fine?
Andrew
You're probably right (as usual :roll: ) Mind you neither picture shows #1 chamber and valves...maybe that's melted off which is why his hand is at #2 :mrgreen:
Seriously though I wonder what the chamber inserts look like?  The one must have melted right out. Back to the Krell issue How come I only hole an aluminum sacepan with a gas cooker flame when it boils dry; yet the flames are hotter than diesel aren't they? :?
Mark-The-Miser-UK
Reply #4May 03, 2007, 04:19:00 am
« Reply #4 on: May 03, 2007, 04:19:00 am »
i dunno... diesel can have some serious BTU's...  just takes a little bit on a campfire to take the chill out  :lol:
Reply #5May 03, 2007, 06:02:17 am
« Reply #5 on: May 03, 2007, 06:02:17 am »
Ever hear of those cutters that use liquid jets at high pressure? Hot metal is softer, and could probably easily be eroded by high pressure Diesel jet.
Reply #6May 03, 2007, 08:12:08 am
« Reply #6 on: May 03, 2007, 08:12:08 am »
The rest of the head looked perfectly normal. The chambers all seemed fine, the valves looked fine as did the cups. You guys can probably notice alot of carnage on the head... I used a hammer to take it apart lol.
