Author Topic: k24 vs gt2052v vs k26?  (Read 6475 times)
April 22, 2007, 11:45:51 am
zaprzal
  • 160
    • turbodiesel.pl
« on: April 22, 2007, 11:45:51 am »
What would you put on 1.6td? Can I make much more power with gt2052v than with k24?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #1April 23, 2007, 05:37:46 am
Benjamin
  • 485
« Reply #1 on: April 23, 2007, 05:37:46 am »
i think you can get more with a vnt20 than a k24. but problebly not that much.
the vnt20 will spool quicker than the k24.
Greetz, Benjamin
Must make +250hp
Reply #2April 25, 2007, 04:46:20 pm
SMOKEYDUB
  • 630
« Reply #2 on: April 25, 2007, 04:46:20 pm »
i have found that a k24 will take you past the limits of you engine...it will provide enough boost to be unreliable  :lol:
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3April 25, 2007, 05:13:50 pm
« Reply #3 on: April 25, 2007, 05:13:50 pm »
the vnt-20 is definitely too big for the 1.6 engine.  maybe for a heavily modified 1.6 with head studs, etc...
the vnt-15 is already a really suitable turbo.  check Jake's VNT rabbit thread... he was able to blow boost tubes on part throttle!  his turbo also created boost at idle by blipping the pedal.
if you found a way to mechanically control the vanes reliably, then the VNT would be a great solution to quick response, and severely out-perform the K24.
Reply #4April 26, 2007, 07:02:46 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #4 on: April 26, 2007, 07:02:46 am »
k24 blows hot air and I can't burn all fuel that 10mm pump can deliver... What do you think about k26 diesel turbo?
Reply #5April 26, 2007, 08:01:22 am
Audi80
« Reply #5 on: April 26, 2007, 08:01:22 am »
VNT20 is not big for 1.6, I´m running GT23V... Boost is not everything you need.
You could try K26 from Mercedes 300 12V DT. It is pretty commonly used here at 1.6 and 1.9.
Reply #6April 26, 2007, 08:06:04 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #6 on: April 26, 2007, 08:06:04 am »
I can cheaply get k26 from Iveco diesel truck, put into k24 housing - hybrid :)... I think I'll try it. What do you think?
Reply #7April 26, 2007, 09:34:03 am
Benjamin
  • 485
« Reply #7 on: April 26, 2007, 09:34:03 am »
Quote from: "Audi80"
habba  :D
you have some more info about it, boost, 0-100km/h, 400m sprint, rpm range, hp, plunger... ?
Greetz, Benjamin
Must make +250hp
Reply #8April 26, 2007, 09:48:39 am
Audi80
« Reply #8 on: April 26, 2007, 09:48:39 am »
habba  :D
Greetz, Benjamin
Hmm, more info of what?
I had this combo in ´85 Audi 80. With vnt20 0-100 ~7,1, 1/4 mile 15,5/145kmh. With GT23V 0-100 ~6,8 1/4 mile 15,0/150kmh. Otherwise same car with 10mm pump. I ran out of fuel with 10mm plunger, now I have 12mm. Can´t wait to get it running again :D
Whp dynos
Third one is otherwise same motor, only differences are stock T3 Garrett with 0,7 bar boost, stock revs in pump and 1 turn less fueling.
Reply #9April 27, 2007, 11:02:38 am
Benjamin
  • 485
« Reply #9 on: April 27, 2007, 11:02:38 am »
how much km's did you drove with the 150whp?
Greetz, Benjamin
Must make +250hp
Reply #10April 27, 2007, 12:19:32 pm
Audi80
« Reply #10 on: April 27, 2007, 12:19:32 pm »
~15K with each head  :lol:
Had a lot of heating problems, could be air bubbles in coolant. Never found the reason, but it cracked the head a couple times :?
