Author Topic: Blocking BOV  (Read 12858 times)
December 15, 2004, 03:17:35 pm
GTD.
  • 183
    • http://tinyurl.com/6yk84
Blocking BOV
« on: December 15, 2004, 03:17:35 pm »
I've blocked off my BOV with a bit of reinforced hydraulic hose I had lying around and a 3/8" to 1/4" socket adapter and some jubilee clips.
The BOV vented to the intake pipe so I fitted a breather filter to were it connected to the intake pipe.
Anyone know of a better/neater solution?
Its a SB 1.6 IDI TD engine.
Cheers
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #1December 15, 2004, 04:39:06 pm
fspGTD
  • 1529
Blocking BOV
« Reply #1 on: December 15, 2004, 04:39:06 pm »
No need for the breather filter on the blow off valve outlet.  It's just a feature to protect the engine from overboost in the event of a stuck closed wastegate, so it never actually lets air flow through it when things are working the way they should.
Jake Russell
Reply #2December 15, 2004, 06:30:19 pm
vwmike
  • 1158
Blocking BOV
« Reply #2 on: December 15, 2004, 06:30:19 pm »
Quote from: "fspGTD"
Why would overboost really be a bad thing on a diesel? Wouldn't running infinite boost just continue to cool egt's and increase combustion efficiency, or would the LDA still supply enough fuel to burn up the engine? It's my understanding that they eliminated the pop valve on the Eco Diesel intake which makes me assume that this has to do with the latter.
Reply #3December 15, 2004, 09:55:38 pm
Blocking BOV
« Reply #3 on: December 15, 2004, 09:55:38 pm »
Actually boost = heat.  And the turbine creates a lot of heat, because the exhaust gases are compressing as well.
Intercooling would definitely decrease temps though!  As for combustion efficiency, you would need an intercooler after 9 or so psi.  After that the air's oxygen levels arent good enough to ensure a clean burn (and you can tell when your car is leaving a black cloud behind it... brings back memories in summer time, but not in winter :)
fspGTD mentioned in a book that there was diesel tractors with 200 psi boost.  That is some MEAN power right there.  If anyone could get 200 psi on a vw diesel, they would be my hero!!! LOL (good luck... its half the pressure needed to ignite the diesel.... w0w intercooling would have to be water spray!!!!!)
Reply #4December 15, 2004, 10:26:19 pm
vwmike
  • 1158
Blocking BOV
« Reply #4 on: December 15, 2004, 10:26:19 pm »
Quote from: "jtanguay"
That's not exactly how I've understood things. Yes, with a gas engine running more boost will create detonation after a certain point due to increased cylinder pressures and decreased air density due to heat. Running more boost when more fuel isn't available will increase heat which can cause engine damage regardless of detonation.
When you consider your standard diesel compression check ought to yeild results in the 400+ psi range, it seems like a drop in the bucket to add a little extra boost. But I suppose in theory if we run 1 bar of boost we effectively double cylinder pressures. Of course this will lessen as boost increases due to the heat generated by compressing the air.
From everything I've read, tuning a diesel is more like an excercise in chasing your tail. Ultimately, excess fuel will melt pistons, not boost. With a lean burn engine like this, adding boost will essentially lean the engine out, or reduce engine load - which ultimately reduces EGT's.
If I'm overlooking something , feel free to chime in  :D
Reply #5December 16, 2004, 08:17:26 am
QuickTD
  • 1156
Blocking BOV
« Reply #5 on: December 16, 2004, 08:17:26 am »
It would, until the physical limits of the turbo are reached and the compressor wheel bursts due to excessive speed. The other enemy is cylinder pressure. As you said, doubling the intake pressure will double the cylinder pressure. This will catch up to you at some point.
 Boost is  limited to a safe level on later models by underfueling them. No fuel = no heat = no boost. I don't think a  stock 1.9TD with the wastegate tied shut could really hurt itself.
 You've pretty much got it, The only limit to the amount of power you can make is the physical strength/heat resistance of the parts. You can compound turbo's to easily obtain 70psi of boost. If you can get the rods, pistons and head gasket to hold then you could make some huge power. :D
Reply #6December 16, 2004, 10:31:34 am
vwmike
  • 1158
Blocking BOV
« Reply #6 on: December 16, 2004, 10:31:34 am »
Quote from: "QuickTD"
I haven't actually heard of much of an issue with the compressor wheel coming apart. As Deo stated, they were running over 35 psi on the stock turbo.
Reply #7December 16, 2004, 11:20:50 am
GTD.
  • 183
Blocking BOV
« Reply #7 on: December 16, 2004, 11:20:50 am »
I think you've misunderstood me I blocked the bov outlet with a bit of hydralyic hose with a 3/8" to 1/4" socket adapter stuck in it as a plug and held it in place with a worm drive clip.
The breather filter is is on the inlet pipe where the bov outlet would connect to, if I didnt use a filter, the turbo and engine would be drawing in unfiltered air.
I was just looking for a neater "Plug", I'll post pics up tomorrow.
I know the BOV is to leak overboost back in to the inlet pipe, I want to up my boost pressure from 0.6 to 1.1 BAR by using a manual boost controller on the wastegat line thats why I've blocked my BOV outlet, also my engine is intercooled as it left Wolfsberg as I said in my post, Its a SB 1.6 IDI TD engine.
Cheers
[Oo=w=oO]Golf GTD
Reply #8December 16, 2004, 01:09:20 pm
fspGTD
  • 1529
Blocking BOV
« Reply #8 on: December 16, 2004, 01:09:20 pm »
Gotcha, thanks for the clarification.  :)
Have you seen this cross-section diagram of the BOV?
I found that the stock range of adjustment maxxes out at an operating pressure of about 14psi (a little under 1 bar), which doesn't sound like enough for your needs.  I have heard that if you unscrew the adjuster completely, you can install a shim behind it (going between the threaded adjuster and the spring that is behind the adjuster) that can cause it to raise it's operating pressure higher than the stock adjustment range, or if the shim is thick enough, lock the position of the valve completely closed (accomplishing the same thing as capping the air outlet.)
Stock intercooled 1.6lTD... nice motor... you know those weren't available in north america.  drool!
Jake Russell
Reply #9December 16, 2004, 01:32:44 pm
GTD.
  • 183
Blocking BOV
« Reply #9 on: December 16, 2004, 01:32:44 pm »
No worries, no I aint seen that pic before, I might have to make a little test light up. might make it permanant with a LED on the dash.
 I never thought of adjusting and shimming the BOV as I thought I'd have to strip it down and replace the spring with a firmer one.
 Might be worth doing as a safety feature in case of damage to the hose suppling the wastegate or MBC just in case I didnt notice it on the boost guage.
 Yes, although I only found out after ordering a Bentley A2 manual as there isnt a UK workshop manual for a Golf MK2 diesel, this model was only avaliable in the UK for the last year or so of production, I was lucky to find one at the local salvage auction, so I decided to save it by rebuilding it.
 Fortunatly the A2 Bentley covers similar US spec A2 TD engines, and is usefull for other stuff.
Cheers
[Oo=w=oO]Golf GTD
Reply #10December 16, 2004, 06:21:31 pm
QuickTD
  • 1156
Blocking BOV
« Reply #10 on: December 16, 2004, 06:21:31 pm »
So why doesn't VW run all there diesels at 35 psi boost? At that boost level the 1.6TD could have made well over 150hp and still got 50mpg. Also, nothing improves emissions performance like boost, it helps with NOX, particulate, hydrocarbons, everything. If it can be done with the stock turbo, stock internals and with 100000mile reliability whats the holdup? In fact, why the hell am I not doing this? I had no clue that my 200+hp 1.9TD was just a chopped wastegate hose away... :D
Reply #11December 16, 2004, 09:11:05 pm
Blocking BOV
« Reply #11 on: December 16, 2004, 09:11:05 pm »
Lol QuickTD...  Man I would LOVE to have 200 HP and 50 mpg!!!  WHERE DO I SIGNUP???
Haha!
Reply #12December 16, 2004, 09:41:51 pm
srivett
  • 318
Blocking BOV
« Reply #12 on: December 16, 2004, 09:41:51 pm »
What size of plug do you need?  VW sells a 5/8" rubber antifreeze cap for about a buck.  It is like a rubber thimble that goes onto the metal coolant hose...covers the connection for the oil cooler if you don't have the turbo.  My rad cap keeps about 25PSI in the system so it ought to be sturdy enough.
Steve
1992 1.6D Golf - 412K km
Reply #13December 17, 2004, 12:01:07 am
GTD.
  • 183
Blocking BOV
« Reply #13 on: December 17, 2004, 12:01:07 am »
Quote from: "srivett"
Steve
According to the A2 Bentley BOV test procedure the plug is 1"/25mm, but thats for a plug to fit in the hoses.
 That thimble like cap might stretch over the BOV outlet, have you got a part number for it?
cheers
[Oo=w=oO]Golf GTD
Reply #14December 17, 2004, 10:29:19 am
vwmike
  • 1158
Blocking BOV
« Reply #14 on: December 17, 2004, 10:29:19 am »
I don't know what world of magically exploding turbos you come from, but around here they just wear out faster and start to smoke. I think it's pretty damn obvious why vw didn't have cars running 35psi from the factory, that doesn't mean you can't do it. My Gas Rabbit makes almost triple the stock power output.....sure VW didn't do it from the factory, but I did it anyways.
