Author Topic: 1.6 IDI Timing Advance Mod.  (Read 64709 times)
Reply #45March 18, 2008, 08:53:25 pm
« Reply #45 on: March 18, 2008, 08:53:25 pm »
So your running a NA engine correct?
130 bar injectors?
What is your timing set at?
I have a fresh 1.6 TD with a K24 with 3" turbo back.
injectors are huge but set @ 139 bar
Timing set at about .95 and I have a 10mm pump.
It doesn't seem to matter much how I drive it (still new only 2 tanks) I'm getting a solid 40 mph.
Also I'm running an ACH trans with a 3.67 R&P and a .75 fifth gear.
I run @ 75 both ways.
I'm wanting to set the timing @ 1.0mm and get some smaller injectors (stock) to see if that will help bump me up a tad.
I'm also thinking if I fix the cruise I will get better, I have a heavy foot, love seing the smoke and hearing the turbo wind up.
Reply #46March 19, 2008, 12:51:22 am
« Reply #46 on: March 19, 2008, 12:51:22 am »
yup, 1.6NA, 130bar injectors with maybe 16,000 miles on 'em, my timing was at .97 or .98...can't remember, and I fixed my internal IP pressure and that made the timing advance much more effective and then it rattled way to much so I retarded the timing as much as possible w/o it shaking. That made it run quieter, less smoke :cry: but the power stayed about the same. My tranny is a FN, 3.89 final and .71 5th.
Maybe unhook your LDA hose and see what your mileage does, of course, then you would have an eco diesel :roll: How big of improvement was your 10mm plunger over the 9mm? I'm building an IP and wanna get more power w/o hurtin' mileage, and I'm thinkin' of getting a 10mm pump.
