Author Topic: Well, my waterpump finally went  (Read 6872 times)
Reply #15April 03, 2007, 01:06:56 pm
Cheesetoast
  • 285
« Reply #15 on: April 03, 2007, 01:06:56 pm »
Quote from: jtanguay
maybe there's an airlock impeding coolant flow??? try to bleed that out asap!
coolant temps are good though, wouldn't that cause some high temps?
Reply #16April 17, 2007, 09:57:11 pm
Cheesetoast
  • 285
« Reply #16 on: April 17, 2007, 09:57:11 pm »
mechanic looked at her today.  a piece of metal got into the timing belt, my lifter closest to the belt is in multiple pieces, camshaft is chipped on the edges  for that lifter, new lifters going in, new cam too.  he'll see how it sounds after that, not sure if i bent any valves yet.  :(
Reply #17April 17, 2007, 11:16:16 pm
Cheesetoast
  • 285
« Reply #17 on: April 17, 2007, 11:16:16 pm »
doh, any idea on cost to replace the valves?
Reply #18August 10, 2010, 04:29:23 pm
wildenbeast
  • 50
    • The WILDENBEAST
Re: Well, my waterpump finally went
« Reply #18 on: August 10, 2010, 04:29:23 pm »
My 14 month old waterpump went today.  I am interested in finding the cast one mentioned by Andrew.  I searched but didn't find much.  Anyone know where to find these?
If you heat up very hot the housing and small bolts a few times and douse them with penetrent they usually come free.  Many of the stock pump/housing combo units are assembled using loctite.    :roll:  Add a little rust to the scene and you can very easily snap every bolt.  Whenever I get a new housing I remove each of the bolts and reinstall with anti-sieze rather than loctite.   :wink: Get the cast impeller variety rather than the plastic or stamped steel ones.  Any know where to get cast ones?
Andrew
1990 Syncro Adventurewagen
1.9 Turbo Diesel (AAZ)
http://billwildenberg.shutterfly.com/vwvanagon
Reply #19August 10, 2010, 05:54:07 pm
RadoTD
  • 513
    Stage WTF
« Reply #19 on: August 10, 2010, 05:54:07 pm »
I got a Febi-Bilstein (sp) that had cast aluminum impellers. Ordered through Worldpac... I assume it's the same from them for Canada and US
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #20August 10, 2010, 07:16:05 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #20 on: August 10, 2010, 07:16:05 pm »
Yep all my bolts broke off on my pulley and the water pump it self.
Does anyone know of the parts # of the pulley or the water pump body?
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #21August 10, 2010, 09:05:47 pm
