Author Topic: Golf AHU imobiliser problem. Going into T25 Vanagon...  (Read 9115 times)
March 22, 2007, 03:44:12 pm
EMPI748
  • 11
« on: March 22, 2007, 03:44:12 pm »
Hi,
Hopefully someone here can give me a bit of help.  Possibly not a good question for a first post but am not sure what to do.
Am putting a 1997 golf 1.9 TDi AHU engine into a 1988 T25 Vanagon.  I have the sump etc changed over an ready to fit.  However have a bit of a problem..... :(
The key appeared to have a built in immobiliser trigger and there was a ring sensor on the ignition switch.  However due to an idiot at work the key has been sent to the scrap yard and was crushed before i found out :evil: I had originally planned on leaving the whole loom intact and taping the key to the ring so I would not have to worry about it.
However with it being lost I now need a way to get round the immobiliser.  Does anyone know how to do this?  Can i just remove something to disable it?
Cheers
Stu
Reply #1March 25, 2007, 07:37:47 pm
vwmike
  • 1158
« Reply #1 on: March 25, 2007, 07:37:47 pm »
You should  be able to get around the immobilizer by switching to the North American software. We had the MSA 15.5 management on the AHU engines but with no immobilizer.
Reply #2March 26, 2007, 03:10:11 pm
Slave2School
  • 531
« Reply #2 on: March 26, 2007, 03:10:11 pm »
Yes Get the ECU reprogrammed for some extra power and have the immo deleted at the same time :D
2002 ford focme wagon
Reply #3April 03, 2007, 02:47:19 pm
EMPI748
  • 11
« Reply #3 on: April 03, 2007, 02:47:19 pm »
Thanks for the replies...
Had a look at getting it remapped and the only places I found wanted more than double what the engine cost  :shock:
Any ideas?
Reply #4April 03, 2007, 03:58:27 pm
« Reply #4 on: April 03, 2007, 03:58:27 pm »
hehe you guys make it sound so easy to disable the immobilizer... hmmm is it that easy to steal a newer v dub?   :lol:
Reply #5April 05, 2007, 03:38:14 pm
vwmike
  • 1158
« Reply #5 on: April 05, 2007, 03:38:14 pm »
Quote from: jtanguay
You don't want to know.
And I could help out with the immobilizer delete....the distance being the major stumbling block.
Reply #6August 01, 2007, 12:00:47 pm
HirMiller
  • 8
« Reply #6 on: August 01, 2007, 12:00:47 pm »
Hello, I am fitting a 1Z to my t25/t3 and have the identical problem, NO KEY! did you find a solution?
Cheers
Jason
If it was meant to go fast, it wouldn't be shaped like a brick!
Reply #7August 07, 2007, 12:03:32 pm
MikkiJayne
  • 235
« Reply #7 on: August 07, 2007, 12:03:32 pm »
Hmm plenty of people have hinted they can do this, but so far no-one in the UK actually has. Or at least they haven't posted it here if they did!
It seems pretty common in the US, but I haven't found anyone here who can do the OBDI ECUs - only OBDII in later cars. I think because OBDII can be remapped / reprogrammed online, whereas OBDI needs the EPROM re-written and is therefore much harder.
The only solution I found was to find another donor which did have the key, and get the key, immo box and ECU complete. Either that or post your ECU to Rocketchip...
Sorry I can't help any more than this.
Mikki x
Reply #8August 11, 2007, 05:06:59 am
sidelights
  • 6
« Reply #8 on: August 11, 2007, 05:06:59 am »
Hi,
I have used this guy for reprogramming diesel ecu's twice and he is the best I've used so far.
Tamar Electronics
Unit 7 Stowford Business Park
Filham Moor
Ivybridge
Devon
PL21 0BE
01752 894519
Bren
Reply #9August 14, 2007, 09:56:09 am
HirMiller
  • 8
« Reply #9 on: August 14, 2007, 09:56:09 am »
I tried Tamar Electronics but they can't remove the Immobiliser, Need to keep searching I guess.
Reply #10August 14, 2007, 12:47:33 pm
Reply #11August 14, 2007, 02:01:30 pm
HirMiller
  • 8
« Reply #11 on: August 14, 2007, 02:01:30 pm »
Cool, I will try him tomorrow.
Cheers
Jason
Reply #12August 17, 2007, 09:13:21 am
MikkiJayne
  • 235
« Reply #12 on: August 17, 2007, 09:13:21 am »
Any luck?
Reply #13August 26, 2007, 02:15:03 pm
HirMiller
  • 8
« Reply #13 on: August 26, 2007, 02:15:03 pm »
Hi, been away.
£135 plus P&P, seems reasonable? I am also down another track which I will post on the forum today.
I was told an older ecu will work because they don't have immobiliser prior to 1994 (europe).
Reply #14January 08, 2008, 01:53:33 pm
t3-umbau.de
  • 1
« Reply #14 on: January 08, 2008, 01:53:33 pm »
Hi,
we can disable the Immo of the MSA15 (ecu in metal housing, not the old one in black plastic housing), EDC15, EDC16 ecu and we also can read out the secret key code of the immo-boxes (Audi, Seat, Skoda, VW Golf, VW T4, and so on)
For more questions, please write me an email or PN.
Max
PS: an older ecu won't work correctly with the AHU engine (missing external altitude sensor)!
