Author Topic: 1.9 AAZ bling ??  (Read 8090 times)
Reply #15July 07, 2007, 04:36:20 am
stewardc
1.9 AAZ bling ??
« Reply #15 on: July 07, 2007, 04:36:20 am »
Looks like I'll just have to chrome it, or powdercoat and use some other blingage. I got this in the mail yesterday. The cover will vent into it with some nice braided lines....
Reply #16July 07, 2007, 04:37:22 am
stewardc
1.9 AAZ bling ??
« Reply #16 on: July 07, 2007, 04:37:22 am »
Quote from: "subsonic"
I thought I saw one in one of Dave's posts(g60).  One of his his nice pictures of goodies.  Could be wrong though.
Would anyone know whwew this post/poster is? I cannot find it.
Reply #17July 07, 2007, 07:24:34 am
Kudagra
  • 738
    • www.no-coast.com
1.9 AAZ bling ??
« Reply #17 on: July 07, 2007, 07:24:34 am »
Why dont you take a 1.9 gasket in to a shop and have a flange made...then TIGed to your g60 cover..smooth it all out...machine it flat...and run it.
Maybe too much work..but you would have the only 1.9/g60 valve cover.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #18July 07, 2007, 08:09:34 am
stewardc
1.9 AAZ bling ??
« Reply #18 on: July 07, 2007, 08:09:34 am »
That's actually a great idea, but the present cover bolts down through the top of the cover. I have heard that the untapped holes are in the gasket surface to bolt down that way, but I haven't looked at that yet. Be assured, I'll do something nice. :D  :wink:
Reply #19October 08, 2007, 12:20:30 pm
stewardc
1.9 AAZ bling ??
« Reply #19 on: October 08, 2007, 12:20:30 pm »
Yeeeehaaaahh !!!! I just got the call. My truck is finally done. I pick it up tomorrow.
 :D  :D  :D  :D  :D  :D  :D  :D  :D  :D
Reply #20October 08, 2007, 01:12:14 pm
Black Smokin' Diesel
  • 656
1.9 AAZ bling ??
« Reply #20 on: October 08, 2007, 01:12:14 pm »
The gasket surface is the same, I bet you could drill and tap the head to fit the G60 cover on and remove the studs on the cam brackets.
Reply #21October 08, 2007, 01:16:28 pm
regcheeseman
  • 714
1.9 AAZ bling ??
« Reply #21 on: October 08, 2007, 01:16:28 pm »
Gibber's got a TDI cover on his AAZ - sure he won't mind me bigging it up...
Reply #22October 08, 2007, 01:54:35 pm
1.9 AAZ bling ??
« Reply #22 on: October 08, 2007, 01:54:35 pm »
Quote from: "stewardc"
I wonder if this is what you were thinking of ?
http://vwdiesel.net/phpBB/viewtopic.php?t=7676
Reply #23October 09, 2007, 11:39:00 am
stewardc
1.9 AAZ bling ??
« Reply #23 on: October 09, 2007, 11:39:00 am »
HOME at last and workin FINE !
Reply #24October 10, 2007, 05:57:50 pm
subsonic
  • 1836
1.9 AAZ bling ??
« Reply #24 on: October 10, 2007, 05:57:50 pm »
Quote from: "zukgod1"
Yup.  That was the one.  My bad.  ALH not AAZ.
Reply #25October 10, 2007, 06:34:02 pm
blkboostedtruck
  • 1535
1.9 AAZ bling ??
« Reply #25 on: October 10, 2007, 06:34:02 pm »
stewardc,
was that you bidding on that white face cluster on E-bay?
I think your valve cover should be made custom by a cnc milling machine and then have it fully polished! I put a G60 fully polished valve cover on my    1.6 TD caddy and it looks real good!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #26October 10, 2007, 07:11:03 pm
stewardc
1.9 AAZ bling ??
« Reply #26 on: October 10, 2007, 07:11:03 pm »
Yup, that was me.
Here's my G60 cover on my 1.6 before transplant.
Reply #27October 10, 2007, 08:55:02 pm
blkboostedtruck
  • 1535
1.9 AAZ bling ??
« Reply #27 on: October 10, 2007, 08:55:02 pm »
so how does it feel going from a 1.6TD to a 1.9TD is there a big noticable difference? I envy you cause i wanna jump to a 1.9TD in my caddy someday!
well did you win that cluster?
thanks Duane
'66 variant 1500S
Reply #28October 11, 2007, 03:17:47 am
stewardc
1.9 AAZ bling ??
« Reply #28 on: October 11, 2007, 03:17:47 am »
Yes, I did win the cluster ($20). :D
The 1.9 is certainly a different beast, though I only have about 100 miles on it yet. It is noisier and has slightly more vibration. The torque is unbelieveable. It will pull as hard in 5th as the 1.6 does in 3rd. Keep in mind that the 1.9 is all new and highly modified (though presently only running 8 psi boost) whereas the 1.6 was worn out.
