Author Topic: Calling Dave ( PP ), Malone And Dr. D GTD vs Merc injectors  (Read 19911 times)
February 26, 2007, 07:11:06 pm
subsonic
  • 1836
« on: February 26, 2007, 07:11:06 pm »
Taken from: Making the jump N/A to TD
Well, the man said to ask you. So........
Subsonic wrote
Injectors / nozzles: Lots and lots of information. Some say no change, just difference between old and new. More fuel at higher pressure is better, but what is the upper end? With all the nozzles I see for sale out there, is there a difference in spray pattern? Are certain spray patterns better suited for 1.9’s or 1.6’s? Many I see don’t actually say what size the nozzle is. I would expect that this would be one of the pieces of information Giles would need to get you the correct pump set up.
jtaguay replied:
[/quote]The stock, gtd, 1.9td are all so close that it won't make much differnt to Giles for the pump setup, but if you do have them already, then it wouldn't hurt either, the biggest baddest ones out there are really hard to get ahold of as Jake is preoccupied with other things, but the dieselicous ones are supposed to be huge, agian I know Malone has a set, but they are untested to this point. Merc nozzles provide better flow then any of the vw ones. I know that Malone and Dave @ PP tested some ahwile back and so they probably would be the ones to ask about this. As well Dr. Diesel had shaved the pintle or shimed the pintle for more lift and got a fair bit more out of the stockers iirc.
What kind of results did you guy's see?  Which injectors did you test? Are the Merc ones comperable to Dieselicous nozzles?
Thanks Jim
Reply #1February 26, 2007, 07:16:00 pm
subsonic
  • 1836
Damn instructions!!!
« Reply #1 on: February 26, 2007, 07:16:00 pm »
OK, that's not exactly how it was supposed to come out :?
Have patience, I'll figure out this quote  code list stuff eventually :oops:
Reply #2February 28, 2007, 07:02:19 am
  • 1156
    • Malone Tuning Ltd.
« Reply #2 on: February 28, 2007, 07:02:19 am »
I lost about 10 HP after switching from brand new OEM injectors to brand new GTD nozzles (swapped into used injector bodies & pop-tested). The GTD injector set however had a slightly higher breaking pressure, which may have affected fuel timing. Still, the question of GTD gains over new OEM injectors remain.
You'll surely see an improvement if you get new GTDs (or whatever new nozzles) over an old set of nozzles. New nozzles replacing worn ones will restore fuel economy, power, and reduce smoke.
With MB 300D injectors I think I felt a little more power.. but I was running NA at the time, not under boost, and it was very dark out so I couldn't tell how much extra smoke there were. I would test these injectors again with boost. I don't have a running TD at the moment though.
I still have the prized Dieselicious nozzles, they're rare.. I really wish my TD's running so I can try these nozzles, but it'll have to wait.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #3February 28, 2007, 07:05:11 am
« Reply #3 on: February 28, 2007, 07:05:11 am »
I'm actually feeling a bit of a drop in performance myself with the GTD injectors... maybe i'll try advancing my pump to see if it helps any... so far i think my economy went up a little though :) and there is a little less smoke.
Reply #4February 28, 2007, 07:10:59 am
  • 1156
« Reply #4 on: February 28, 2007, 07:10:59 am »
If I need new VW injectors I would probably buy brand new OEMs (preferably brand new, not refurbished) instead of GTDs. It costs more though, about 265 CAD for a set if I remember correctly unless you find a good source.
The power loss with GTDs was very noticeable. I have not been convinced that advancing the timing a bit to compensate for the higher breaking pressure will not only restore the lost 10HP, but also gain a few more HP.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #5February 28, 2007, 11:41:14 am
Mark(The Miser)UK
  • 1557
« Reply #5 on: February 28, 2007, 11:41:14 am »
Quote from: malone
[/size]
Do oem GTD injectors have different springs to standard? so that you don't get GTD effects with only GTD nozzles? Perhaps this accounts for the powerloss? I'm just speculating here  but.... if power is related to fuel volume in any given situation then loss of power must (may)(partly) be due to less fuel. If both springs were set to the same tension (opening bars-wize) but the pintle travels further in   a pure GTD setup due to a weaker spring then the standard springs would 'open less' and give less fuel ...eh??...:roll:  {bit convoluted sorry}
Mark-The-Miser-UK
Reply #6February 28, 2007, 03:18:10 pm
935racer
« Reply #6 on: February 28, 2007, 03:18:10 pm »
I've run a few sets of the MB complete injectors on a few locals rides now, definately more power than GTD or OEM, not a huge kick in the pants but every bit counts :wink:
Reply #7February 28, 2007, 09:10:01 pm
subsonic
  • 1836
Hmmmmm....
« Reply #7 on: February 28, 2007, 09:10:01 pm »
Does anyone actually say what the flowrate,or opening size is on nozzles?  Sometimes I see a number designation and other times it is just described as more powerful.  What Merc injectors where you using?
Just how big are these bad ass dieselicious injectors?
I am starting to move off theroretical and will need some soon.
Thanks, Jim
Reply #8March 01, 2007, 07:03:44 am
  • 1156
« Reply #8 on: March 01, 2007, 07:03:44 am »
I should have noted that the GTD nozzles I tried were aftermarket, not genuine. A brand new set of genuine GTD injectors may be slightly better than standard 1.6TD injectors but they're likely more expensive.
The Dieselicious custom nozzles flow about 64% more than what GTDs flow over stock if I remember correctly.
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #9March 01, 2007, 09:07:35 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #9 on: March 01, 2007, 09:07:35 am »
Do you have a link for the Dieselicious nozzles?  I did a google search and got way too many links for gay porn.
Calvin
91 VW Golf 1.6NA 5spd
Reply #10March 01, 2007, 09:54:18 am
  • 1156
« Reply #10 on: March 01, 2007, 09:54:18 am »
:lol:
fspGTD on this board produced these nozzles. He named his company Dieselicious and he did business only on this site as far as I know, which is why you didn't find non-homoerotic links anywhere else.
He was one of the most valuable contributors to the IDI community, but a few months ago he disappeared online. Presumably to concentrate more on his fatherly duties.
fspGTD's webpage, although outdated, has his e-mail address on it:
http://home.comcast.net/~vwgtd/
You may have a better chance reaching him via email. I sort of doubt he's continuing production of the Dieselicious nozzles (I imagine it's labour-intensive), but it doesn't hurt to ask.
Cheers,
Mark
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #11March 02, 2007, 07:30:39 pm
2mAn
« Reply #11 on: March 02, 2007, 07:30:39 pm »
i have been trying to get ahold of jake sincei  moved to seattle. it drives me nuts knowing he lives in the same city as me and i have yet to meet the man :x
Reply #12March 03, 2007, 12:25:43 pm
Mark(The Miser)UK
  • 1557
« Reply #12 on: March 03, 2007, 12:25:43 pm »
Anyone have a clue if GTD springs have a different characteristic to OEM?
Mark-The-Miser-UK
Reply #13March 03, 2007, 06:35:39 pm
935racer
« Reply #13 on: March 03, 2007, 06:35:39 pm »
Yeah where the hell is Jake? :?
Reply #14March 06, 2007, 08:04:42 pm
subsonic
  • 1836
64%!!
« Reply #14 on: March 06, 2007, 08:04:42 pm »
64% over stock GTD! Damn!  Has anyone actually run these dieselicious injectors in thier rides.  Back in the day before midnight diaper changes, what did a set go for? Man with these and the GSP (Giles Super Pump  :) ) you must be pumping out the fuel like the Valdeez.
