Non VW Group Diesel
1.6 td in caravan
Topic: 1.6 td in caravan (Read 6858 times)
February 22, 2007, 11:15:07 pm
LeeG
1.6 td in caravan
February 22, 2007, 11:15:07 pm »
http://www.youtube.com/watch?v=J_0l-zI_pzc&NR
'97 Passat TDI
February 25, 2007, 05:50:59 am
bvolks73
1.6 td in caravan
February 25, 2007, 05:50:59 am »
I've been planning to do that for years but never got around to it. I even have a Dodge 5 speed from an old Omni that had the Rabbit motor with all the proper mounts, clutch, starter etc. It would be too easy.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
February 25, 2007, 02:21:25 pm
1.6 td in caravan
February 25, 2007, 02:21:25 pm »
cool it's an ontario van
Gets better mileage then my freakin Jetta too
February 25, 2007, 10:29:20 pm
LeeG
1.6 td in caravan
February 25, 2007, 10:29:20 pm »
He seems to have figured out how to connect the dodge shifter to VW tranny as he mentioned welding Dodge and VW axles together to get the tranny in.
I was suprised by the mileage claim too, the caravan has got to be both heavier and less areodynamic.
'97 Passat TDI
February 26, 2007, 08:07:21 am
1.6 td in caravan
February 26, 2007, 08:07:21 am »
I thought he just installed the whole vw shifter linkage. Aren't the shifters on those vans normally on the steering column?
February 26, 2007, 08:55:46 am
LeeG
1.6 td in caravan
February 26, 2007, 08:55:46 am »
Some of the early Caravans had a 5spd, I've never seen one, but have seen them advertised. Most are automatic and column shifted. The one in the video doesnt look like a VW shifter
Column shifted standard transmisions? That is what I learned to drive on, but other than forklifts, I havent seen one newer than early 70s base model 6 cylinder chev trucks. I always thought they were cool to drive, but the linkage was a bit of a bear when it got worn a bit.
'97 Passat TDI
February 26, 2007, 01:43:02 pm
1.6 td in caravan
February 26, 2007, 01:43:02 pm »
I bet his speedo is wrong. ot much of a surprise the shifter works, the Caravan design was bought from VW by Dodge, and it is just a cheaper bloated rabbit.
February 27, 2007, 04:14:42 am
lesharoturbo
1.6 td in caravan
February 27, 2007, 04:14:42 am »
Dodge did have a 5-speed in their caravan. Circa 1991, I rode in one with a turbo 4 cylinder (2.2 liter I believe). It was a hoot to drive and ride in. Pretty quick for a van. I believe it had a Sport designation.
Look at this :
http://research.cars.com/go/crp/research.jsp;jsessionid=M14HBY2LNI0PLLAYIJDZXLA?myid=3586&makeid=12&year=1992&logtype=6&revid=&modelid=127&mode=§ion=summary&mode=&aff=national
Bernie
February 27, 2007, 04:18:04 am
lesharoturbo
1.6 td in caravan
February 27, 2007, 04:18:04 am »
BTW, that is the Dodge 5 speed shifter.
Bernie
Non VW Group Diesel
1.6 td in caravan
