Author Topic: GTD clocks with rev counter into mk1  (Read 10805 times)
February 20, 2007, 11:52:34 am
redbaron
  • 21
« on: February 20, 2007, 11:52:34 am »
Hello all i have a 1991 Caddy 1.6 with a GTD engine installated by myself. I have been hankering over a rev counter for a while and have mangaed to source a set of GTD clocks. Trouble is wiring is not my strongpoint and the colours dont all match up.
The wires are as follows:
The colours on the caddy are: Blue/Grey, brown, purple/black, yellow/red, red/black, red, blue/white, blue/black, blue/green, yellow, blue, blue/red and black.
The GTD clocks are: Blue (x2), L.green (x2), blue/white, black, red/yellow, grey, green/white, brown, red, red/white (x2), purple, yellow.
ANy ideas which ones connect up to which?
So far i think ive worked out a few from looking at wiring diagrams, but im not at all sure!
Any help greatly appreciated
Reply #1February 20, 2007, 12:30:35 pm
« Reply #1 on: February 20, 2007, 12:30:35 pm »
I'm pretty sure we will need wiring diagrams since most of us don't have any of these parts and have never seen them.
Reply #2February 20, 2007, 06:54:34 pm
koen GTD
  • 9
« Reply #2 on: February 20, 2007, 06:54:34 pm »
Multi stekker dashboard caddy                Golf gtd
Klemnr.   color            Function                color         nr.
1           grey-blue    Dash light             grey             12
2           brown             const massa       brown          3
3           purple-black     fuel       meter     blue         21
4           yellowl-red     temp meter          yellow-red      23
5           red-black      rev counter             green           10
6           red                        12V               red             11
7           blue-white    high beam           blue-white       25
8           -
            blue -black  oil cont                    yellow                9
10         bleu-green  warming up plug IND   green-white    20
11         yellow               oil contr             red- white       8
12         blue              dynamo IND       blue           16
13         blue-red        blinker                  green           24
14          black  massa                          black         13
often not in  caddy;  Coolant low level   rood-wit      2
                                      connet to  massa
Diesel Boost
Reply #3February 21, 2007, 12:47:11 pm
redbaron
  • 21
« Reply #3 on: February 21, 2007, 12:47:11 pm »
Koen GTD you are a legend!
Thanks. Lots!
 8)  8)
Reply #4February 21, 2007, 12:53:56 pm
TomB
  • 88
« Reply #4 on: February 21, 2007, 12:53:56 pm »
redbaron, where did you manage to track down a set of GTD clocks with a tach?  I've been scouring fleabay but to no avail...
Cheers,
Tom
1.6 Golf GTD - Chip Fat Powered!
Reply #5February 21, 2007, 07:41:26 pm
  • 5065
« Reply #5 on: February 21, 2007, 07:41:26 pm »
rabbit diesel tach:
jetta/eurodash tach:
Reply #6February 21, 2007, 08:13:18 pm
« Reply #6 on: February 21, 2007, 08:13:18 pm »
lol "unleaded fuel sucks"
Reply #7February 22, 2007, 05:27:44 am
redbaron
  • 21
« Reply #7 on: February 22, 2007, 05:27:44 am »
I got them from ebay, someone listed as breaking a golf gtd. £25 delivered. I had been looking for a while.....
Now ill kknow when to shift! usually just been waiting till the power drops off!
Reply #8February 23, 2007, 07:35:16 am
redbaron
  • 21
« Reply #8 on: February 23, 2007, 07:35:16 am »
Ok got clocks in and working, cant get flashing red coolant warning light to go off. comes on about 15 seconds after starting. As far as im aware there is no sensor on the caddy! I have a red/white and a purple wire left over so im guessing its one of those. Does it need a voltage supply or and earth or what to shut it up?
Cheers
Reply #9February 24, 2007, 06:00:55 pm
koen GTD
  • 9
« Reply #9 on: February 24, 2007, 06:00:55 pm »
these are my clocks
they are from a golf mk2  GTD european
I have them in my   golf mk1  GTD
Diesel Boost
Reply #10December 28, 2013, 12:58:15 pm
carraca
  • 12
Re: GTD clocks with rev counter into mk1
« Reply #10 on: December 28, 2013, 12:58:15 pm »
Hi,
I am installing GTD cluster in a '84 passat TD.
I can't make the rev counter work. I have to say that I made a mistake with the two green wires and contected the green wire of the tach to the blinker (which is 12v constant) instead of the W terminal.
I heard a buzzing sound from the cluster and inmediately disconected it.
Rewired it but the tach is dead.
Did I fried the tach? How can I check it?
Also, how do I check if the W terminal is providing a signal?
There are three spare wires, two white/red at possitions 2 and 9 and a purple one in possition 7. Should I contect the three to ground?
Thanks!
Marcos
1984 VW Passat Variant (32b) 1.6TD
1972 VW 1302S (2109cc)
Fixmyvw.com
