I went to hunt down the reason for my non-op tach today and I found some clues and a couple more questions:
Clues:
The "W" terminal has a white plastic connector insterted into it, with no wire connected to it. I tried to remove the connector so I could see how to properly connect a wire, but I couldn't get it to budge.
Coming out of a harness of other wires that go to the alternator, I found a red wire with a black stripe that had been cut-off.
Hypothesis:
I'm assuming that this red and black wire is for my tach and that I need to connect it to the W terminal.
Questions:
Do I have this right? Is the red and black wire for the tach?
If so, how can I connect it to the W terminal?
Anything I'm overlooking/ should know?
Thanks in advance
