Author Topic: Building a Hydraulic 1.6 TD for Severe Punishment?  (Read 6402 times)
February 13, 2007, 07:40:53 am
myke_w
  • 1099
« on: February 13, 2007, 07:40:53 am »
Hey all,
I just picked up an old POS Jetta TD with a 1.6 Hyd motor in it.
I am hoping to go through this motor and do a bore job, block and head cleaning and throw in all new needed internals, etc... I am very familiar with the 1.6 mechanical motors, but not so much the hydraulic ones.
If all goes well, this motor will be the donor for a wicked fun autocross car.
I gather that the mechanical motors have a bit more power potential because of more precise valve adjustment, is this just because of dilapidated lifters that nobody wants to replace?
I am eager to do a metal head gasket, and possibly load new lifters in it.
Beyond the obvious of using good quality parts, is there anything else internally I can do to prepare this motor for a serious beating?
I plan to run a modded pump for high revs, gtd nozzles, an intercooler and lots of fuel and boost, and I want this sucker to hang together for a good long time.
I guess I'm looking for a parts/mods list for a bad ass 1.6TD build
 8)
Reply #1February 13, 2007, 08:12:22 am
saurkraut
  • 904
« Reply #1 on: February 13, 2007, 08:12:22 am »
When you tear into it, look at the lifter bores.  You might be able to run solid lifters in the hydro head.
I have a new 1.9 hydro head.  The oil ports for the hydro lifters are in the side of the bore more than half way up the bore.  The lifter bores look to be the same diameter.   I'll be doing some measurements this weekend between the 1.6 mech head and the 1.9 hydro head to see what might work.
My intension is to convert this head to a mechanical head and put it on my 1.6 mechanical motor for the bigger ports and lower compression ratio.  this moter is in my summer rabbit, so i cold starting should not be an issue
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2February 13, 2007, 04:48:05 pm
myke_w
  • 1099
« Reply #2 on: February 13, 2007, 04:48:05 pm »
Curious if the cam is the same.. IIRC the valves are different between the 2 models.. Is it definitive that the hydraulic lifters rob power in a noticable way?
Reply #3February 13, 2007, 05:40:05 pm
« Reply #3 on: February 13, 2007, 05:40:05 pm »
Where can you find new lifters?
Reply #4February 13, 2007, 07:17:48 pm
myke_w
  • 1099
« Reply #4 on: February 13, 2007, 07:17:48 pm »
I can get them from my supplier..
If you need some let me know..
9 bucks each shipped in the US.. to CA... have to check..
Reply #5February 13, 2007, 07:40:38 pm
« Reply #5 on: February 13, 2007, 07:40:38 pm »
well i can honestly say that it felt like i had more power down low with my mech engine... the hyd one is alright though...
my proof came from a fully loaded car getting up to speed as if it were fully empty... with my current car i had it half loaded, and it was super sluggish... now that could always be due to bad lifters and bad injectors etc... but my old car wasn't really a prize either  :lol:
Reply #6February 13, 2007, 09:51:46 pm
ODwyerPW
  • 103
    • http://www.Espanglish.com.mx
« Reply #6 on: February 13, 2007, 09:51:46 pm »
935Racer is doing those interesting custom intake and exhaust manifolds too.
83 Rabbit LS Turbo Diesel
Reply #7February 14, 2007, 12:22:31 am
« Reply #7 on: February 14, 2007, 12:22:31 am »
Quote from: "ODwyerPW"
yea i totally forgot about those... they will certainly open up the little diesel, and decrease turbo spool times by quite a lot :)
Reply #8February 14, 2007, 01:11:01 pm
myke_w
  • 1099
« Reply #8 on: February 14, 2007, 01:11:01 pm »
refresh my memory.. should I be using a TDI headgasket?
Reply #9February 14, 2007, 01:23:35 pm
« Reply #9 on: February 14, 2007, 01:23:35 pm »
1.9TD head gasket.  the TDI one won't work
Reply #10February 14, 2007, 01:35:32 pm
myke_w
  • 1099
« Reply #10 on: February 14, 2007, 01:35:32 pm »
Hmm, now... where to find them in the US?
Reply #11February 14, 2007, 02:18:21 pm
« Reply #11 on: February 14, 2007, 02:18:21 pm »
Quote from: "libbybapa"
Myke you need to start selling them.   :wink: Along with total-seal rings and the ARP studs.  :wink:  :wink: Let me know when you have them in stock...
Andrew
I second that!  I really REALLY want some total seal rings for my rebuild!!!
Reply #12February 14, 2007, 02:32:06 pm
myke_w
  • 1099
« Reply #12 on: February 14, 2007, 02:32:06 pm »
Anybody got the skinny on Canadian wholesalers?
Reply #13February 14, 2007, 11:50:10 pm
myke_w
  • 1099
« Reply #13 on: February 14, 2007, 11:50:10 pm »
Andrew
Libby,
Did you mean 1.9 headgaskets? I just found out I can get those too!
If you meant lifters.. I have them next day, then they go out to you..
Myke
Reply #14February 15, 2007, 08:31:24 am
myke_w
  • 1099
« Reply #14 on: February 15, 2007, 08:31:24 am »
Libby,
I've got access to the 1.9 headgaskets.. let me know # of notches.
Studs and rings? None of my guys get that.. I might be able to explore it with a racing wholesaler.
Otherwise, I think you're looking for a jegs or summit race shop :)
The 1.9 AAZ headgaskets aren't exactly cheap.  35 before shipping. I'm a shipping cost only kinda guy, so that shouldn't add a whole bunch.... I think my wholesaler must be importing them and paying provincial tax..
Should I make a post in FS / WTB ?
Off topic a bit..  Since I've been selling the crap out of TD parts, I've been thinking of doing an online website store with all this stuff in to for easy access.. any thoughts on that? I hate ebay cause they stiff me with charges, and it doesn't get me the traffic I like, I'd rather deal with hardcore nuts like y'all.. :) Any thoughts either way?
