Author Topic: which brand of nozzle to choose  (Read 5895 times)
February 05, 2007, 08:38:03 pm
evangelos
« on: February 05, 2007, 08:38:03 pm »
hello all,
i have a 10mm ip, diesel inside chip and veg205 nozzles.
i rescently drove a manual  tdi that was not chipped but had the Basio sprint 205. the engine felt stonger than mine with the chip. so now i want to change to the Basio PP764 (216).
now there are nozzles that have the same size and others that are performance rated with more power or something!!
so now i have a choice,
Dipaco nozzles that are affordable.
Basio nozzles that are very expensive but have a strong reputation
Smog 216 but i do not know if they are VEG 216?
i do not plan on changing my IP but someday when my turbo goes i will change it for the the vnt-17 and i do not want to change nozzles.
can i have some feedback please.
evan
Reply #1February 23, 2007, 08:24:50 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #1 on: February 23, 2007, 08:24:50 am »
I had a set of cheap .216 injectors in my 2003 from www.tdiracing.com and I gave those away because they were very smokey. on my Corrado I just bought a set of PP520s from Kerma and they are less smokey then the .216s and just as powerful if not more powerful.
Reply #2February 23, 2007, 09:22:15 am
Seafarer12
  • 28
« Reply #2 on: February 23, 2007, 09:22:15 am »
The tdi also probably had an 11mm pump head.
Reply #3February 23, 2007, 09:30:40 am
evangelos
« Reply #3 on: February 23, 2007, 09:30:40 am »
actually my modification plans just changed.
i will be adding an 11mm head , Caddy .240mm nozzles or pp520 (depends how bad per power they each smokes), ARP headstuds. i will still be using the stock smic and i wonder if there will be smokey difference if swaped for fmic?  not to mention i will be adding an external lift pump.
i was told i will be hitting close to the 280lb of torque, this is a concern because its my wife daily driver so i want to keep acceptable mpg numbers.
any feedback please
evan
Reply #4February 23, 2007, 11:26:15 am
  • 1156
    • Malone Tuning Ltd.
« Reply #4 on: February 23, 2007, 11:26:15 am »
With all these fueling upgrades you can get your chip updated for little or no smoke.
During your chip update you can also ask to keep your torque peak controlled for drivetrain reliability. For example, limit the torque peak to approximately 240wtq, and that won't affect high-RPM horsepower.
280 wheel torque is unlikely reliable for the stock VNT-15 turbo anyway.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #5February 23, 2007, 02:39:42 pm
evangelos
« Reply #5 on: February 23, 2007, 02:39:42 pm »
what kind of hp would i be looking at?
Reply #6February 23, 2007, 02:58:26 pm
  • 1156
« Reply #6 on: February 23, 2007, 02:58:26 pm »
125 to 135whp, depending on the dyno. A 130whp car can be exaggerated to 150whp on the right dyno (e.g. with 17% "correction factor").
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #7February 23, 2007, 06:46:56 pm
evangelos
« Reply #7 on: February 23, 2007, 06:46:56 pm »
do u guys think driveshaft axels should be upgraded as well?
are the 1.8T driveshafts the same as the vr6 version?
what other tuning can be done to minimize the smoke?
thanks for the help,
evan
Reply #8February 23, 2007, 07:20:45 pm
Slave2School
  • 531
« Reply #8 on: February 23, 2007, 07:20:45 pm »
I have 0 complaints with my smog .216's they are nice and smooth not smoky at all.
2002 ford focme wagon
Reply #9February 26, 2007, 06:43:48 am
nkb
  • 154
« Reply #9 on: February 26, 2007, 06:43:48 am »
Quote from: Slave2School
i can vouch for s2s car not being smoky.. except for the tires heheheh
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #10February 26, 2007, 08:13:49 am
  • 1156
« Reply #10 on: February 26, 2007, 08:13:49 am »
I don't think your drive shafts need to be upgraded... what clutch do you have?
BleachedBora carries great A3 TDI stuff at good prices.. here's his mild bolt-on turbo upgrade:
http://forums.tdiclub.com/showpost.php?p=1461290
More stuff & pricing:
http://forums.tdiclub.com/showpost.php?p=1455922
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #11February 26, 2007, 08:57:53 am
evangelos
« Reply #11 on: February 26, 2007, 08:57:53 am »
the g60/vr6 clutch i have.
