Author Topic: Brake Question..  (Read 5611 times)
February 05, 2007, 05:58:24 pm
sju
  • 32
Brake Question..
« on: February 05, 2007, 05:58:24 pm »
So i did a search, and everyone is complaining of soft or squishy brake problems. i just picked up an 82 diesel that sat in a field for like a year,  all hoses need replaced it looks like, it starts and runs fine, but when i went to move it yesterday i about ran the thing into my garage, i can stomp on the pedal as hard as i can, and it barely stops it. My buddy mentioned some pump maybe not functioning?
Any help would be awesome.
thanks.
80 diesel caddy
82 jetta diesel(parts car)
84 rabbit gti(daily)
89 golf gl
89 jetta (soon tobe wifes daily)
Reply #1February 05, 2007, 06:57:26 pm
somolovitch3
  • 290
Brake Question..
« Reply #1 on: February 05, 2007, 06:57:26 pm »
Brakes are "power" brakes.  Booster is the big black drum between master cylinder and firewall.
It needs a source of vacume to work.
There is a vacume pump where the distributer would be on a gasser.
Check and see if you have vacume at the pump, Booster and possible for your AC/Heating controls, if you have AC.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #2February 05, 2007, 07:03:18 pm
sju
  • 32
Brake Question..
« Reply #2 on: February 05, 2007, 07:03:18 pm »
much thanks
80 diesel caddy
89 golf gl
Reply #3February 05, 2007, 08:19:12 pm
Brake Question..
« Reply #3 on: February 05, 2007, 08:19:12 pm »
dont forget to bleed your brake system because after a while it turns corrosive and starts eating hoses etc...
Reply #4February 25, 2007, 07:29:30 pm
sju
  • 32
Brake Question..
« Reply #4 on: February 25, 2007, 07:29:30 pm »
about how much vacuum show i bee seeing out of this pump..?
a buddy made it seem like  i shouldnt be able to put my thumb on it and pull it off easy, he said he thought maybe 20 inches of vac or something.... does that sound right or even close?
80 diesel caddy
89 golf gl
Reply #5February 26, 2007, 06:36:19 am
Brake Question..
« Reply #5 on: February 26, 2007, 06:36:19 am »
supposedly the vacuum pump is able to pull a full vacuum... that should be enough to make it a bit painful for your thumb  :lol:
Reply #6February 26, 2007, 08:39:15 am
Brake Question..
« Reply #6 on: February 26, 2007, 08:39:15 am »
TURN IT OFF! TURN IT OFF! TURN IT OFF!
Reply #7February 26, 2007, 08:30:23 pm
sju
  • 32
Brake Question..
« Reply #7 on: February 26, 2007, 08:30:23 pm »
Quote from: jtanguay
well its definitely not working the way it should then, ill have to pursue this a little further.
80 diesel caddy
89 golf gl
Reply #8February 27, 2007, 08:49:54 pm
hipifreq
  • 89
Brake Question..
« Reply #8 on: February 27, 2007, 08:49:54 pm »
If your vac pump isn't pulling hard enough to take some effort to remove your thumb, then you should pull it and get a diaphragm kit and a valve kit for it. It's an easy job to do, especially with the Bentley. Just be sure you put the valves in the right way! Also, you'll need two o-rings that don't come with either kit. One is small, and is inside the pump, and the other is large and fits between the pump and the block. I recently did my own VP, so ask if you've got questions.
Your other problem may be in the booster. If you're leaking vacuum in the booster diaphragm, then you'll need to replace the whole thing. It's much more expensive to do that than the vac pump, so do the pump first.
I also second the flushing of fluid throughout the whole system. If the cars been sitting then you should replace the caliper seals and wheel cylinders.
I can't stress how much more important it is to be able to _STOP_ the car than it is to get it going.
Reply #9February 28, 2007, 05:10:04 am
BlackTieTD
  • 1512
Brake Question..
« Reply #9 on: February 28, 2007, 05:10:04 am »
good advice hipifreq.
i second the diaphragm advice. when i got my '82 rabbit diesel, one of the first things that broke on it was the vacuum pump. so i bought a diaphragm kit and good as new. easy job to do, if you get stuck let us know. if its not producing vacuum then that's the first place to start IMO. get that sorted then move on to the booster if you think that is also shot. good luck.
Reply #10February 28, 2007, 06:34:30 pm
sju
  • 32
Brake Question..
« Reply #10 on: February 28, 2007, 06:34:30 pm »
thats what my buddy suggested i do, and know youve confirmed this
thanks and im sure ill ask some questions, as ive yet to get a manual for the diesel yet.
basically i got this car for free, they quit driving it, probably do to the brakes not working. Spent only a couple of hours tooling with it, after reading your forums  i got it started,  i just need to do some work to it now, diapham kit, new fuel filter, new oil filter, flush and change all fluids, replace the hoses that go from injector to injector, and back to the IP, timing belt..
Any info on sites that are good for buying, hose and stuff, would  be awesome too.
and here is a photo of the bucket your are helping me revive.
outside is fairly clean, inside is mint. not even a saggy headliner
[/img]
80 diesel caddy
89 golf gl
Reply #11February 28, 2007, 09:50:02 pm
hipifreq
  • 89
Brake Question..
« Reply #11 on: February 28, 2007, 09:50:02 pm »
You guys have biodiesel out there in Spokane? I'm in Bellingham, and it's readily available all up and down Puget Sound. If you're into using it I would recommend a Viton hose kit from greaseworks.org. They've got all the specs for the hoses, and for just over $100 you can get the full kit. Complete kit to replace all fuel lines, and it has the clamps.
Reply #12February 28, 2007, 10:48:46 pm
sju
  • 32
Brake Question..
« Reply #12 on: February 28, 2007, 10:48:46 pm »
Quote from: hipifreq
i think we have 3 or 4 biodiesel places.
ill definately look into that thanks.
80 diesel caddy
89 golf gl
