Author Topic: FS: 1.6 Oil Pumps w/ 36mm gears (HD mech upgrade)  (Read 13057 times)
Reply #15January 25, 2007, 02:03:32 pm
myke_w
  • 1099
« Reply #15 on: January 25, 2007, 02:03:32 pm »
Most definitely made in Germany.
Made by Meyle a big supplier of all kinds of after market parts.
I will supply pics shortly.
Reply #16January 25, 2007, 02:23:10 pm
myke_w
  • 1099
« Reply #16 on: January 25, 2007, 02:23:10 pm »
See pics here.. warning ther are quite large..
http://oak.cats.ohiou.edu/~mw105397/pics/Parts/028115105G/
Reply #17January 25, 2007, 06:42:37 pm
RabbitGTDguy
  • 1274
Re: upgraded oilpumps
« Reply #17 on: January 25, 2007, 06:42:37 pm »
Myke W,
       Are these oil pumps made in Germany? I purchased a higher volume oil pump from the Parts Place Inc. and it turned out to be one made in China( the three words I hate the most) . It was inferior looking from a quality standpoint -looked like the machining was done on a hobby lathe. Then they charged me a restocking fee when I returned it-I will never buy a thing from those clowns again.
        Thanx,
        Pete
I've had similar experiences with parts place and won't buy from them again either. They advertise one thing....and sold another.... haven't been back since. When I voiced my concerns, etc...man...customer service wasn't par either...
Joe
1972 VW Westfalia
Reply #18January 25, 2007, 08:44:10 pm
myke_w
  • 1099
« Reply #18 on: January 25, 2007, 08:44:10 pm »
Ok, I'm a big dummy. Don't worry, the deal is still god, the pump is still made in Germany and all that.
One minor detail about the part - Standard mechanical head pumps actually had 26mm gears.
I measured tonight - This pump, and all the newer ones, ie 9a, aba, ahu, 1z, probably even aaz have 30mm gears.
I threw the one in the pics in my TD Vanagon this evening and it really boosted pressure at speed and even a bit at idle..
Anyway, FWIW.. :)
Reply #19January 25, 2007, 10:21:05 pm
tbro
  • 34
« Reply #19 on: January 25, 2007, 10:21:05 pm »
Myke W, I have a German Import JR code 1.6 TD hydraulic  engine.  I have been fighting Oil Pressure issues since day one.  Engine had only 48,000 miles on clock when imported with excellent numbers all around except OP.  Idle, 8 PSI, and at 2200 RPM, 24 PSI measured warm with mechanical gauge.
Cold, I am at 26 lbs idle and 68 lbs @2200 RPM. I suspected  the intermediate shaft bearings were going South until I read your post.  Do you really think I can gain acceptable oil pressure with your setup?  I would much prefer removing the pan and NOT the whole engine if possible!  What can I expect for oil pressure with the 36mm gears in a 1.6 TD engine?  Any comments you can add I would appreciate.  I am used to much higher numbers as my NA engines run in the 70 PSI range at 2200RPM, but these are all mechanical lifter engiines, not TD hydraulic.  Tom
Reply #20January 26, 2007, 04:29:47 am
myke_w
  • 1099
« Reply #20 on: January 26, 2007, 04:29:47 am »
I would suspect your car came with this pump, since it has a hydraulic head..
This is not really a remedy to low oil pressure on a tired motor - It's more of an upgrade from stock to get more oil pressure out of the gates..  If you did go this route, I think you would be just delaying the inevitable..
Reply #21January 26, 2007, 11:08:41 am
mvptrukin
  • 19
« Reply #21 on: January 26, 2007, 11:08:41 am »
myke_w,
      Definitely good quality, I wish I had pictures of the one made in China-the tip of the drive shaft was uneven and when you turned the shaft there was play and a loud rumbling sound. Anyhow I didn't see them on your ebay store should I order one over here? Do these require the longer mounting bolts, which I have?
        Thanx,
        Pete
Reply #22January 26, 2007, 12:13:44 pm
myke_w
  • 1099
« Reply #22 on: January 26, 2007, 12:13:44 pm »
My paypal is [email protected]
I'd prefer to avoid the ebay store if not just for the damn fees.
I am pretty sure the bolt length is the same. IIRC it's only the body of the pump that is clearenced for the gears, so the body is the same length as the old ones, also has to be that way for proper pickup clearance.
I generally need a day or so to turn them around..
I will put pics of the gears next to each other tonight so you can see the difference.
Reply #23January 26, 2007, 03:16:49 pm
Typrus
  • 93
« Reply #23 on: January 26, 2007, 03:16:49 pm »
Forgive my ignorance.... Is there a significant difference between the 1.5 and 1.6 oil pumps? More oil is always a good thing...
1995 Toyota Camry 2.2L 5-speed
1984 Toyota Tercel 4wd Wagon 1986 "           "           "      "
1996 VW Passat TDI 1Z w/ KermaTDI Stage 3 kit
1999.5 F-250 7.3L Powerstroke
2002 Excursion 7.3L Powerstroke (Dads)
Reply #24January 26, 2007, 04:03:14 pm
myke_w
  • 1099
« Reply #24 on: January 26, 2007, 04:03:14 pm »
the 1.5 pump would almost certainly have small gears..
Reply #25January 26, 2007, 04:39:02 pm
Typrus
  • 93
« Reply #25 on: January 26, 2007, 04:39:02 pm »
I suppose I should ask if it'd likely work with bigger gears.
Also... I just noticed page 2 and read briefly.... 30mm on a 1Z? And yours are 36mm? Hmmmm.... Anything that'd help the life of our 1Z might be loved by my mom....
Reply #26January 26, 2007, 05:32:57 pm
myke_w
  • 1099
« Reply #26 on: January 26, 2007, 05:32:57 pm »
Let me clarify..
Old pumps - pre-hydraulic - 26mm gears - #068-115-105NA
This pump - hydraulic lifter motor - 30mm gears - #028-115-105G
Same pump as later hydraulic motors, same as 1z, ahu
Sorry about the confusion.. I'm an idiot  :wink:
Reply #27December 31, 2008, 02:05:12 pm
« Reply #27 on: December 31, 2008, 02:05:12 pm »
Hey Mike, this isn't the pump you got on your website is it?
'Cause your website says 36mm gears. Just curious, here you say it's 30mm gears and I'm just wondering which one I got from you. Thanks :)
Let me clarify..
EDIT: You mustuv upgraded since this post, I did some searches and found were people measured your's and said they're 36mm.  :)
Reply #28December 31, 2008, 03:47:19 pm
myke_w
  • 1099
« Reply #28 on: December 31, 2008, 03:47:19 pm »
sorry - if you got it from me - it has 36mm gears unless you requested 30mm :)
