Author Topic: LITTLE plunger  (Read 5341 times)
January 20, 2007, 02:41:08 am
nkb
  • 154
LITTLE plunger
« on: January 20, 2007, 02:41:08 am »
i wonder if this plunger is too big for our cars??? hahaha
this thing is huge, it pumps like 30 tons of fuel a day at 110 rpm!! :shock: talk about  fuel economy
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #1January 20, 2007, 09:58:59 am
AdAm84
LITTLE plunger
« Reply #1 on: January 20, 2007, 09:58:59 am »
hmmm..... I wonder if my n/a rabbit will smoke with that plunger set up :lol:
Reply #2January 20, 2007, 12:53:33 pm
LITTLE plunger
« Reply #2 on: January 20, 2007, 12:53:33 pm »
that thing is a monster... its quite easily 1/3 the size of our whole injection pump itself...  if you could do a side by side comparison that would make a great avatar lol
Reply #3January 20, 2007, 11:44:12 pm
nkb
  • 154
LITTLE plunger
« Reply #3 on: January 20, 2007, 11:44:12 pm »
i would but it is just some pic i found while serching for diesel stuff, looked interesting enough
2004 Jetta TDI
1986 S-10 LT1
Reply #4January 21, 2007, 08:28:47 am
Ziptar
  • 565
LITTLE plunger
« Reply #4 on: January 21, 2007, 08:28:47 am »
Reply #5January 21, 2007, 11:17:37 am
LITTLE plunger
« Reply #5 on: January 21, 2007, 11:17:37 am »
300 ton crank... ummm
Reply #6January 21, 2007, 12:05:58 pm
LITTLE plunger
« Reply #6 on: January 21, 2007, 12:05:58 pm »
Instead, in this engine the top of the connecting rod attaches to a "crosshead" and a long piston rod then connects the crosshead to the piston. This lowers the sideways forces produced by the connecting rod and is absorbed by the crosshead and not by the piston. Sideways forces are what makes the cylinders in an auto engine become oval-shaped over time.
very interesting... i wouldn't want to do an oil change on that thing...  :shock:
108,920 hp at 102 rpm ummm...  that is many many horses!
Reply #7January 21, 2007, 01:10:18 pm
LITTLE plunger
« Reply #7 on: January 21, 2007, 01:10:18 pm »
I guess you just need to replace the guides when you rebuild the engine?
Reply #8January 21, 2007, 02:09:57 pm
LITTLE plunger
« Reply #8 on: January 21, 2007, 02:09:57 pm »
thats a really interesting setup...in reality the crosshead guide wear limit could be virtually unlimited, and still provide excellent wear reduction in the cylinder walls...  i wonder which other companies are going to be streamlining this new technology...
Reply #9January 21, 2007, 04:22:56 pm
QuickTD
  • 1156
LITTLE plunger
« Reply #9 on: January 21, 2007, 04:22:56 pm »
Quote from: "jtanguay"
New technology? I don't think so. The very earliest steam engines used crossheads so that they could seal the piston rod and make the engine double acting. 2 stroke marine diesels have always used a crosshead design since inception (early 1900's?) so that the under-piston scavenge space can be sealed from the crankcase. Nothing new there.
 Crosshead designs would produce engines too tall for automotive use.
Reply #10January 22, 2007, 04:56:41 pm
AdAm84
LITTLE plunger
« Reply #10 on: January 22, 2007, 04:56:41 pm »
couldn't a design like the chrysler slant six be used? they had long strokes so they were tilted to fit the engine under the hood. ........just an idea
Reply #11January 22, 2007, 08:45:50 pm
LITTLE plunger
« Reply #11 on: January 22, 2007, 08:45:50 pm »
Reply #12January 23, 2007, 06:09:41 pm
AdAm84
LITTLE plunger
« Reply #12 on: January 23, 2007, 06:09:41 pm »
thanks. i didn't fully unnderstand the concept. great idea though.
Reply #13January 23, 2007, 06:35:34 pm
LITTLE plunger
« Reply #13 on: January 23, 2007, 06:35:34 pm »
yeah I had no idea what was going on either so I googled it and I figured I should share my results
