Author Topic: Benefits of an inline fuel pump  (Read 14727 times)
Reply #30January 22, 2007, 04:38:29 am
« Reply #30 on: January 22, 2007, 04:38:29 am »
Quote from: "jtanguay"
i think some failures of these pumps could be related to wiring... i've had times where i had a solenoid not work and just because the button i used didn't flow enough power...  i think these little pumps are possibly more power hungry than advertised..
I think that might have to do with where you mount them and how hard they have to work to pump the fuel.
Reply #31January 22, 2007, 12:05:10 pm
veeman
  • 421
« Reply #31 on: January 22, 2007, 12:05:10 pm »
So... the guy in jackbombay's link says he's going to mount his between the filter and the IP.   If the pump pushes fuel, wouldn't it be better to put it before the filter to make sure it's filled while running?   What's the consensus?
I'm interested in this solution... I can never seem to get rid of the bubbles in my supply line no matter how I've tried to look at the different hoses and replace filters.  A bit more of a consistent flow up top to go with the Giles pump would be a good thing too...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #32January 22, 2007, 12:49:37 pm
« Reply #32 on: January 22, 2007, 12:49:37 pm »
i have no idea how this pump actually works or what the internals look like... but just from the sounds of it, think of a speaker and how it 'pushes' air at a certain frequency to create sound.  i believe this pump uses movement like that of a speaker to 'push' fuel, and some sort of check valve so that the fuel that is in the pump at the time of pushing does not go reverse, and when it retracts it does not let fuel back in from the out port.
i cannot see this pump 'priming' itself or even sucking fuel.  the best spot to mount it would be right back at the tank, at the lowest point.  Make sure you have nice thick insulated wires going back there to feed it too.  solder the connections too, do NOT crimp the wires together!  it will work soooo good!
plus, if it is the speaker like type, i only see extreme heat being the culprit for it breaking.  as in any stereo equipment...  but at the same time, extreme cold may wreck the pump if it is using the magnetic pumping system... because the magnets would heat up really quickly they may be prone to 'cracking'  :?
not saying that these pumps are bad or anything... but they're made in China right?  :lol:
http://www.made-in-china.com/showroom/olivercheng/product-detailHQJEKExjxnmA/China-Cube-Solid-State-Pumps-Electric-fuel-pump-.html
