Author Topic: vnt25 on a Tdi-m  (Read 17386 times)
Reply #15March 06, 2007, 12:57:27 am
DA-BRT
  • 140
    • http://Zwalve.eu/
vnt25 on a Tdi-m
« Reply #15 on: March 06, 2007, 12:57:27 am »
Sorry Guy's I've been away for a while (more important personal things)
This weekend I'm driving north to pick-up the fuelpump and make a copy of the dynoplot.
The engine had been taken appart by the owner to check for status.
@Malone: I took out almost the complete swirl chambre. I gained about 60% more flow.
Reply #16March 06, 2007, 07:53:50 pm
935racer
vnt25 on a Tdi-m
« Reply #16 on: March 06, 2007, 07:53:50 pm »
Bert, any chance you could get pictures of the manifolds and the audi drivetrain stuffed in that rabbit? How much rpm are you spinning with that 14mm head?
Reply #17March 07, 2007, 02:00:40 am
DA-BRT
  • 140
    • http://Zwalve.eu/
vnt25 on a Tdi-m
« Reply #17 on: March 07, 2007, 02:00:40 am »
@935racer: It depends on where the engine is at the moment. I know the took is apart to check the internals. But I don't know if the allready put it back together.
Pictures of the parts in te Rabbit are not a problem.
Reply #18March 07, 2007, 02:10:05 am
shadowmaker
  • 28
vnt25 on a Tdi-m
« Reply #18 on: March 07, 2007, 02:10:05 am »
DA-BRT: Any Bosch number for that 14mm head?
I still have little swirl left, because I thought it will be better for mileage as my van is in everyday use.
2.5TDI 5cyl with 227,7kW and 586,6Nm @ 1,3bar (2??kW @2,0bar)
14,53s 158,88kmh @ 1/4-mile
1980kg with aerodynamics of a barn door
http://www.youtube.com/watch?v=hkSTslJf7Z4
Reply #19March 07, 2007, 02:50:59 am
DA-BRT
  • 140
    • http://Zwalve.eu/
vnt25 on a Tdi-m
« Reply #19 on: March 07, 2007, 02:50:59 am »
@Shadowmaker: After this weekend I got the pump back for changing. I can't remember that there was a number on the plunger/head. But I closely look at it. I bought this head from Ebay.de and I didn't said it was a Bosch head or another make.
Reply #20March 07, 2007, 08:34:50 am
Benjamin
  • 485
vnt25 on a Tdi-m
« Reply #20 on: March 07, 2007, 08:34:50 am »
i wonder if Bosch ever made a 14mm plunger, i thought its only after market
Greetz, Benjamin
Must make +250hp
Reply #21March 07, 2007, 06:50:32 pm
RabbitGTDguy
  • 1274
vnt25 on a Tdi-m
« Reply #21 on: March 07, 2007, 06:50:32 pm »
yah, I'm wondering as well. I believe I had read/looked elsewhere and Bosch only made up to a 12mm unit. I believe the only 14mm heads I've seen on the aftermarket were the chinese ones...
Joe
1972 VW Westfalia
Reply #22March 07, 2007, 07:06:21 pm
935racer
vnt25 on a Tdi-m
« Reply #22 on: March 07, 2007, 07:06:21 pm »
Bosch does in fact only go up to 12mm. I have a 14mm head that I bought from dieselspeedshop.com but I havent installed it yet. How high did this pump rev that you built? I am worried about siezing mine. Also what was the reason for engine dissasembly.
Reply #23March 08, 2007, 01:00:06 am
DA-BRT
  • 140
    • http://Zwalve.eu/
vnt25 on a Tdi-m
« Reply #23 on: March 08, 2007, 01:00:06 am »
@935racer:
The engine is still in his brake in period (i don't know if I describe it correctly) The shiftlight was set at 4500RPM. In the sixt gear it went through 5000RPM easily.
A temperature gauge on the pump would't be any luxury.
The reason for dissasembling the engine was becayse of all the new parts and a racespec. build engine. It's very standard to take it apart after 1500 / 2000 km to check wear marks.
Reply #24December 19, 2007, 11:30:30 am
  • 1156
    • Malone Tuning Ltd.
vnt25 on a Tdi-m
« Reply #24 on: December 19, 2007, 11:30:30 am »
More updates! How's the engine running?
Since removing the complete swirl chamber almost completely, how smooth is the engine at low RPMs?
Pictures and dyno?
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #25February 22, 2008, 09:24:46 am
Helliouse
  • 164
vnt25 on a Tdi-m
« Reply #25 on: February 22, 2008, 09:24:46 am »
Bump...this is to good not to...
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
