Author Topic: VE pump diagram  (Read 9032 times)
November 09, 2004, 01:31:01 pm
cheng
  • 43
VE pump diagram
« on: November 09, 2004, 01:31:01 pm »
I know that sombody on here has a parts breakdown for the bosch pump.
I have tried searching and have been unable to locate it.
Who has this link and will you post it again for me please?
Yea this is a funny story. :cry:
so now that its winter, of coarse I have to replace my glow plugs,no problem.
I put everything back together and the throttle shaft is peeing fuel out like its, well, peeing!
so now I have top off of the pump, and do you think that in one of the four o-ring assortment boxes that I have there would be just one little ring that would fit?
OH NO, that would be entirely too easy!
So here I sit with my car in pieces knowing that I have seen that diagram here and not being able to find it.
enough ***ing, its still the best car I've ever owned
thanx
Ken
80 Rabbit 1.5L
82 Caddy 1.6L
84 Jetta Turbo 1.6L
85 Jetta Turbo, hydraulic
ALL DIESEL ALL THE TIME, BABY!
Reply #1November 09, 2004, 02:20:47 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
VE pump diagram
« Reply #1 on: November 09, 2004, 02:20:47 pm »
What is the pump Bosch number that you need the diagram ?
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #2November 09, 2004, 02:42:21 pm
cheng
  • 43
VE pump diagram
« Reply #2 on: November 09, 2004, 02:42:21 pm »
NR 0 460 494 005
VE 4/9 F2500 R16-2
 068 130 107 A
Its on a 1980 1.5l rabbit
thanx Marc
Ken
80 Rabbit 1.5L
82 Caddy 1.6L
84 Jetta Turbo 1.6L
Reply #3November 09, 2004, 08:56:24 pm
fspGTD
  • 1529
VE pump diagram
« Reply #3 on: November 09, 2004, 08:56:24 pm »
Check out this page - I've got some blow-up diagrams of VE pump stuff there...
http://home.comcast.net/~vwgtd/vepump.htm
Jake Russell
Reply #4November 12, 2004, 09:55:05 am
cheng
  • 43
VE pump diagram
« Reply #4 on: November 12, 2004, 09:55:05 am »
hey I finally found it.
It was on the old site here is the link to that post
http://www.hostboard.com/cgi-bin/ultimatebb.cgi/ubb/get_topic/f/4037/t/590
Ken
80 Rabbit 1.5L
82 Caddy 1.6L
84 Jetta Turbo 1.6L
Reply #5November 12, 2004, 02:28:33 pm
AntonUK
VE pump diagram
« Reply #5 on: November 12, 2004, 02:28:33 pm »
Hey Cheng, I take it you didnt work on the pump at all it just started leaking? I had same problem when I took the head off and put it all back together to find it leaking at the throttle shaft. Im positive that i didnt hit it or anything (well I must have then?) but I tried to take the shaft apart and broke my torx bit, after which it stopped leaking.
Never really had a problem since. I do notice though if I move the saft a bit when the engine is not running, I can hear air sqeezing through somthing around the shaft. Anyway hope you get it fixed!
Reply #6November 14, 2004, 02:03:51 pm
RedRotors
  • 734
VE pump diagram
« Reply #6 on: November 14, 2004, 02:03:51 pm »
In case you want the original exploded view of your pump...
Marc/
91' VW Golf Country
-> www.hflox.com <-
