Author Topic: ok, im officially a TD, now i want more boost  (Read 10502 times)
Reply #15January 07, 2007, 05:41:58 pm
DVST8R
  • 535
« Reply #15 on: January 07, 2007, 05:41:58 pm »
Quote from: "jtanguay"
should be listed in the faq as:  How to Melt your Engine!
The funny thing is I ran my motor like that for 2+ years, I blew one turbo, after having run it at 35psi+ for a year. I killed 2 stock clutches and then went to a six puck clutch and went through 3 020's in two months. The engine still ran fine, with stock HG, and stock head bolts. I only got rid of the car because it had some serious cancer, and body damage. In fact Iirc Dave @ Passenger Performance still has the engine as a long block in his shop. As many members here will tell you I beat that engine everyday.
Heat kills these motors more then anything else. Imho three things that NEED to be watched in order for the motor to survive at what ever fueling you can get out of a stock pump are:  1. Excessive EGT's, 2. High water temps, 3. High oil temps. An aux oil cooler, and an intercooler, go a long way on those, but egt's still need to be watched closely.
But you are absolutely right, if you don't know what you are doing, this recipe can melt your motor. It also is the recipe for power.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #16February 15, 2007, 12:09:46 pm
2mAn
« Reply #16 on: February 15, 2007, 12:09:46 pm »
bringing this back up to the top...
i just got a manual boost controller and i want to install it, so i can turn up the fuel and the boost at the same time.
for fuel, im only going to mess with the star wheel, probably start with one full turn and take it from there...ive already turned the boost pin
as far as the boost controller goes, i just want to double check the vacuum line that i need to T into beforehand.
 heres a pic i stole from another thread
the line pictured here is the one i need to T into, correct?
Reply #17February 15, 2007, 12:30:04 pm
« Reply #17 on: February 15, 2007, 12:30:04 pm »
Quote from: "2manVR6"
BAM! yea man thats the line you want to tap into.  it's the only line going to the wastegate  :wink:
Reply #18February 15, 2007, 12:49:17 pm
  • 1156
    • Malone Tuning Ltd.
« Reply #18 on: February 15, 2007, 12:49:17 pm »
Yeah, that black rubber hose is nice and ripe for snipping (one cut somewhere in the middle). You don't want to "T" into it, though, it should look like this:
image link if the above picture does not show
In the middle of the picture is a manual boost controller in brass colour, with a red sticker. Just below it is the turbo wastegate. The black hose running to the left of the boost controller goes to the compressor housing.
If you use a "T" in the rubber hose between the compressor housing and WG, then the boost will still travel from the compressor housing directly to the wastegate so your boost controller won't do anything.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #19February 15, 2007, 01:22:57 pm
2mAn
« Reply #19 on: February 15, 2007, 01:22:57 pm »
Quote from: jtanguay
thats what i figured, just wanted to make sure before i chopped it up :) its kind of hard to see it at night in my garage
Reply #20February 15, 2007, 07:06:35 pm
2mAn
« Reply #20 on: February 15, 2007, 07:06:35 pm »
Quote from: malone
not sure exactly what to do then, this is the "ebay special" i bought..
http://cgi.ebay.com/ebaymotors/BLUE-MANUAL-TURBO-BOOST-CONTROLLER-FOR-CIVIC-INTEGRA_W0QQcmdZViewItemQQcategoryZ33742QQihZ012QQitemZ220082026115QQrdZ1
no instructions :roll:
Reply #21February 15, 2007, 09:49:57 pm
anarchyx34
« Reply #21 on: February 15, 2007, 09:49:57 pm »
I've been thinking about this a bit lately. If one were to disconnect their wastegate, and let the turbo boost to whatever it wants, without making any fueling changes, you'd be using up whatever leftover fuel is available, netting in a small power increase (and clean exhaust!). So say you do this and you're getting 15psi or whatever. If you make small changes to the fueling, therefore increasing your boost, you still should be running pretty lean because the boost is still limited by the fuel available. So instead of cranking up the fueling and then limiting the boost, and having all this fuel left over (black smoke) creating high egt's, you do it the other way around and you're assured cooler EGT's, because any extra fuel would be automatically soaked up by extra boost anyway. Does this make any sense?
Reply #22February 15, 2007, 11:51:37 pm
« Reply #22 on: February 15, 2007, 11:51:37 pm »
Here's a very similar model:
http://www.diesel-speed-shop.com/index_fichiers/Page3663.htm
French but the pictures are fine... note that the T goes in-line with the wastegate hose and then runs to the needle valve.
Some people do the same thing with aquarium tees and valves.  Basically you're bleeding wastegate pressure to trick the wastegate into thinking the turbo is not putting out as much pressure as it really is.
Reply #23February 16, 2007, 12:35:01 am
carrizog60
  • 978
« Reply #23 on: February 16, 2007, 12:35:01 am »
Quote from: anarchyx34
i have mine this way...
still some smoke as the turbo is not spooling but when spooling it will clear.
if i add more fuel it will start to smoke,even on boost range...
Portugal
Reply #24February 17, 2007, 09:28:11 am
DVST8R
  • 535
« Reply #24 on: February 17, 2007, 09:28:11 am »
Quote from: "anarchyx34"
I have mine this way right now with only some RPM mods, and a really cut fuel pin, on a hard pull I can hit ~30psi, nice and clear the only time it smokes is if I lug it, keep the rev's up and it is nice.
One other note:
In my expericance it is better to run the boost line from the manifold to the boost controller to the wastegate, it helps smooth boost spikes and drops a ton. Then just take and plug the line coming from the turbo.
Reply #25February 17, 2007, 10:48:05 am
« Reply #25 on: February 17, 2007, 10:48:05 am »
Quote from: carrizog60
my wastegate is stuck shut, and really the smoke depends on how you have your lda set.
