Author Topic: What to do with motor out..  (Read 5367 times)
January 04, 2007, 06:20:07 am
wolf_walker
  • 1205
« on: January 04, 2007, 06:20:07 am »
Other than putting a head or gasket on my 1.6, I thought I'd replace gaskets any maybe paint the old thing while it's out.  While I've not bothered with a compression test, it still fired right up in the cold after a single glow plug cycle, oil light goes out quickly, other than nailing injectors and a oil leaky head gasket, it seems as good as always.
So, I figured I'd guy a gasket kit and replace all the gaskets and seals.
Is there anything else worth doing while it's out?  I don't imagine it's going to stay in the next vehicle more than a year while I rebuild my TD.
Thoughts?
Mentat Text Two
Reply #1January 04, 2007, 02:49:52 pm
« Reply #1 on: January 04, 2007, 02:49:52 pm »
if all you want is a year out of the motor, just get the hg done and drive it till it dies.  these motors can take quite a beating and will still go strong.
Reply #2January 04, 2007, 03:36:45 pm
wolf_walker
  • 1205
« Reply #2 on: January 04, 2007, 03:36:45 pm »
True, my TD did about 600K with a re-ring and bearings at around 350K.
And a crapy rebuild head that didn't live half as well as the factory one.   :(
Mentat Text Two
Reply #3January 06, 2007, 09:59:38 am
FineFrank
  • 72
motor out
« Reply #3 on: January 06, 2007, 09:59:38 am »
I'd hose out the engine bay while I had the mill out. Lots nicer to work on, prettier to look at.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants"   -Albert Camus-
Reply #4January 06, 2007, 12:57:26 pm
« Reply #4 on: January 06, 2007, 12:57:26 pm »
yeah do rings and bearings and a meain seal while its out, i would, if you do all the work yourself its cheap, unless your motor needs rebored
Reply #5January 06, 2007, 01:36:20 pm
Barry W
« Reply #5 on: January 06, 2007, 01:36:20 pm »
I have been looking online, and having trouble finding rings for a 1991 1.6L TD. Anyone know a place in canada?
Reply #6January 10, 2007, 01:22:01 am
« Reply #6 on: January 10, 2007, 01:22:01 am »
http://www.autopartsonlinecanada.com/
sometimes they have them in stock, they are all out right now though. I use them alot
