S-PAutomotive.com
Author Topic: Wheel bearings for 10.1 brakes  (Read 2299 times)
December 26, 2006, 01:30:03 pm
zagarus
  • 619
« on: December 26, 2006, 01:30:03 pm »
I just wanted to know if the wheel bearings for a 10.1 brake setup from a mk3 are the same ones on my mk2 1.6L TD.  IT seems the OD is the same at 72mm, but is the inside of the bearing (where the shaft goes in) the same OD?  Im going to be upgrading to 11inch coraddo brakes and i have a full 10.1 setup and so all i need to get are 11inch rotors, coraddo carriers and new pads as well as bearings.
Hope someone can confirm the bearing issue.
Thanks
